    Results 1 to 18 of 18
      Oct 2014
      Octane Boost?
      Forum Members
      Would like to get some suggestions on the best octane boost available.
      I'm in CA and our pump best is 91 octane.
      Coronado, CA
      I use Lucas octane booster form any of your chains like Oreilly's and NAPA. I live in Cali too and it gets expensive putting octane booster in every tank. I think I'm going to take some timing out to run 91 octane. The website says it's for motorcycles but in the stores the bottle doesn't specifically say it's for this or that, just gasoline engines. Here's a link : http://lucasoil.com/products/fuel-tr...octane-booster
      Lucas Motorcycle Octane Booster - A Real Octane Booster! Tested and proven to deliver three times more boost than most other brands. Lucas Motorcycle Octane Booster is a GENUINE Performance Enhancer! Tested and proven to deliver three times more boost than most other brands. It's safe for turbos, oxygen sensors and catalytic converters. Stops knocks, and raises MPG in high compression engines.
      One 15 oz. bottle treats up to 25 gallons of fuel. Not street legal.
      Safe For Any Gasoline Engine
      Key Benefits
      Safe for turbos, oxygen sensors and catalytic converters
      Suitable for use in fuel injected and carbureted engines
      Provides more boost than most other brands
      Promotes clean fuel burn for fewer emissions
      Johnny C.
      Nov 2011
      Riverton, Wyo,
      I use Torco, Ted Jannetty lined me up with it, I buy it off ebay. Comes in qt cans I believe just add one when I fill it up.
      Cincinnati Ohio
      I use Boostane https://www.boostane.com/
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Apr 2012
      Woodstock, IL
      Best Octane Boost
      I used to work at autozone and oreillys.. Best one that I read the label on was NOS brand. Some say "raises your octane by 10 points!!" Then in the fine print "1 point = .1 octane level" .. Literally .. lol.
      -Dale
      SchwartzPerformance
      Oct 2014
      Best Octane Boost
      Any thoughts on Royal Purple Octane Boost?
      Or just Royal Purple products in general?
      I hear one side that octane boost is a gimmick vs the other stating they've seen performance increases with them.
      I am running fuel injection so I assume the cpu will adjust according to the fuel type. Is octane boost like crack? Once you start you can't stop?
      Oct 2010
      Rockaway. NJ
      I use Octane Supreme
      http://www.wildbillscorvette.com/octanesupreme01.htm
      Real Lead, and real FULL points of octane boost....
      Troy
      67GTO
      Sep 2014
      Mix race gas with pump gas, no little bottle of jiz is going to substantially improve any quantity of gas.
      Off the shelf boosters are 100% snake oil.
      Pick a leaded or unleaded race fuel to mix.
      Also find a station that sells a lot of premium, since most premium pump gas is stale due to lack of sales.
      Feb 2002
      Springfield, MO
      ^^What he said!!!^^
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Oct 2014
      Unfortunately race gas is not convenient to where I live. By the time I got to the closest 100 octane station, I would have to fill up, and would be empty by the time I got home.
      Feb 2002
      Springfield, MO
      I'd seriously think about ordering a drum and have it on hand in the garage. It's not as bad as what you may think cost wise.
      Jimmy
      Feb 2008
      Torco or Octane Supreme have been proven in labs to back up what they state. They are the only real deal and you won't find anything legit in auto parts stores.
      '69 Camaro RS/SS "Mercury Rising"
      for more build pics - Instagram @cfxlr8
      Oct 2014
      Best Octane Boost
      Thanks for the input guys.
      Mar 2010
      Okinawa, Japan
      How about LL100? You can't have cats and its hard on wide band O2s but cheap and available at any airfield.
      Oct 2014
      Best Octane Boost
      I think I'm going to try out Torco Accelerator. Seems to be the most intuitive way to boost octane by simply adding concentrated race fuel.
      Nov 2011
      Virginia
      Best Octane Boost
      I've heard good things about this product, but haven't tried it yet myself.
      http://race-gas.com
      Feb 2011
      I use REV-X Adrenaline in my premium and haven't had a lick of problems since. Benn using it for about 2 years now and no detination at all. If I run without it, my motor sounds like a box of marbles got run through it. Here is their site.
      https://www.revxoil.com/REV-X_Adrenaline.aspx
      - - - Updated - - -
      Aug 2015
      NJ
      Quote Originally Posted by DSL View Post
      How did it work out for you? I am going to try Boostane. seems a little more concentrated than Torco and not supposed to turn your internals and plugs orange.
