      Oct 2011
      SPRING HILL,FL
      NEED HELP 2011 CTS-V 6l90 TRANS MOUNT ??
      Installing a 2011 ctsv LSA with 6l90 trans.in 72 C10. I can not fine A trans. mount for it, Any help will be appreciated.
      Apr 2013
      Quote Originally Posted by bill1969camaro View Post
      1964-1972 GM Trucks LS Conversion Kit
      This swap kit is for 1964-1972 GM ½ ton 2 wheel drive trucks. It was designed around our GM LH8 oil pan. Unlike most LS swap parts on the market this kit replaces the frame brackets in addition to the mounts so you'll have clean mounting of your engine and not a mix of parts that are weak and don't work together properly. The frame brackets bolt into existing holes in the frame and locates the engine to give you the most options for front accessories drives. Unlike others, our kit positions the engine so there is no steering interference and maintains the proper drive-line angle for smooth highway cruising. It provides clearance for the factory AC box, power brake booster, and aftermarket suspension components. We offer a complete line of Muscle Rods headers that give unparalleled performance and ground clearance with sizes that are matched to your engine combo. These combined parts offer an easy, strong, and clean installation of your LS engine. See our installation guide for more info on this LS swap.
      Available Transmissions
      120-0002-60 LS and 4L60E to 4L70E
      120-0002-80 LS and 4L80E or 4L85E
      120-0002-89 LS and 6L80E or 6L90E
      Mount and Crossmember Kit
      Includes motor mounts, frame brackets, transmission crossmember, transmission mount, and hardware. Manufactured from the highest grade American made steel. They're laser cut, precision bent, powder coated and feature polyurethane bushings. Comes with a lifetime free replacement warranty on the bushings. $479.00
      http://www.brphotrods.com/products/6...uck/index.html
      Apr 2013
