      Miami, Florida
      Related to custom CNC parts...
      Didn't want to hijack Johns thread so this thread relates to what he's asking for on his transfer case. I've been pondering something along the same lines for my project, although purely cosmetic and non mechanical. I imagine the tolerances would be much lower if that helps at all, but these pieces are BIG. I imagine they would need to be machined from a big chunk of aluminum, maybe 12 x 6 x 8 inches, conservitively!! What I'd like to try to have made are right and left grill inserts for my 69 Firebird. They look like this.....
      and this......
      http://www.parts123.com/parts123/yb....0136d~DACBB~~~
      In the car, to get an idea of scale they can be seen here....
      I don't think anybodies seen that image yet so don't tell anybody!!
      Talk about a pipe dream and low production! I'm probably the only bonehead psychopath on the planet that would even contemplate having a set made, a paying the price!
      I've wondered about emachine.com etc, but didn't know if I might have "friendlier" options available. I'd also have to find someone to render the part into one of those fancy CNC compatible files, or perhaps I could learn to do it on my own?(read..I don't trust myself).
      Am I completely off my rocker? I'm afraid I may have just qualified for the blissfully insane padded room and hugging himself guy of the year award!
      I tried to get the images to display embeded in the message, but could only get the URL's to display. I tried both the Image tool and the Hyperlink tool? Whats the trick?
      Kevin.
      69 Firebird "Eternity"
      Mar 2003
      Kirkland, WA
      I think those would be really cool, but I don't know where you'd be able to get something like that made. You might try calling some metal fabrication shops around where you live.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Jul 2002
      Mesquite, TX
      Can't get the images to display embedded in the post because none of them have an image-like extension (.jpg, .gif, etc). Can't help at all on the machining part.
      May 2004
      Dallas, TX
      If you are just thinking about a one off set for your car then the cost would be well into a few thousand $ min...the programming and setup time would be huge and only ammortized over a couple of parts...not to mention the fixtures/tooling and machine time required.
      If you are thinking about something to market I would consider investing in tooling to cast these parts. Die cast tooling would be $75-100K+ minimum per tool. But die casting is not a good fit until you run 1000+ parts per run. Investment casting tooling would be significantly less expensive, maybe in the $10K range per tool. Investment casting is a good alternative to die casting especially when the production qty.'s are much lower.
