Results 1 to 20 of 37
Thread: LT1 swap, should I?
09-24-2014 #1
LT1 swap, should I?
Here's the deal. I have a 1971 camaro. The build plan is mild pt/ driver.
It currently has a tired 1990 350 truck motor with a performer intake, 600 edelbrock and headers.
On my daily commute, it averages 16mpg.
I would like to build a new engine, with a goal of 400 flywheel hp, or close, and to get milage up to at least 20, with a goal of 25mpg.
I could rebuild the 350, and a roller cam, vortec heads, however, I have access to a complete lt1 and 4l60e, wiring, ECM, etc from a roadmaster.
For the same money I can rebuild the lt1, and already have efi.
I know in the days of lsx, an lt1 swap seems silly, but in reality I can accomplish this for thousands of dollars less than a lsx swap.
So, any advice?
Will the lt1 meet my goals?
Anything to look Out for if doing such a swap?1971 Camaro 427 in waiting
1988 C1500 Daily Driver
09-24-2014 #2is the lt1 free?
09-24-2014 #3
- Jul 2006
- El Paso, Texas
- 411
I used an LT1 from a Roadmaster also in my 65 Chevelle with a Tremec 5 speed and stock 3.31 gears. It was pretty easy to do and like you said, a lot less than the LSx conversions. That being said I have a junkyard LS1 that I will eventually rebuild and install, as time and money allows. I used lt1swap.com for the wiring info and it fit pretty easily into the car. I used a set of SBC long tube ceramic coated headers that I had laying around and they've worked fine. The car runs pretty fast and I use it as a daily driver. 11k miles and no major issues. Don't scrimp on the waterpump and Optispark. Got them from Autozone with the lifetime warranty as I used a cheapie Optispark in the beginning and it would die after running for 30-45 minutes. Changed it to the Autozone one and it's worked fine since. I had the software and equipment to reprogram the computer so I fine tuned it to my needs. You can actually drop the MAF thru programming if you want a cleaner look. As for mileage, I get about 14-15mpg in the city. I think a lot of it has to do with the Flowmaster mufflers. I can't seem to take off normally from every stoplight. <g> Damn roar of the exhaust gets me going every time. <evil grin> If I had a lighter foot I could probably do better on mileage but then I wouldn't be as happy driving the Chevelle. Oh almost forgot. Mounting an AC compressor is a hassle. It seems you may have to notch the frame if you use a stock AC compressor. Forget about aftermarket solutions unless you want to go with an Alan Grove setup or something similiar. It kinda negates the low cost aspect. If you're not running AC you can use an AC delete pulley. They run about $40-50 on ebay. I used one so that I can always find a stock belt at any auto parts store. Hope this helps.
Alex
09-24-2014 #4Yeah, after scraping the car, I should come out with less than $300 in the entire setup.
09-24-2014 #5As much as I would love to build an lsx, cost is just too much for me, either way you go. Or end up with a used assembly.
Basically, I can rebuild my smallblock, and tune the heck out of a carb, or spend $1000 on efi,
or for nearly the same cost, rebuild the lt1 and already have efi.
Or I just install the 12:1 427 and say screw mpg!1971 Camaro 427 in waiting
09-24-2014 #6
- Jul 2006
- El Paso, Texas
- 411
I personally like EFI. It starts everytime I turn the key and I don't have to worry about messing with anything. I'm not a carb guy and I had a really hard time when the Chevelle had a carb. There's no warm up time with the car and the loud mufflers give me plenty of old school muscle car feel for me. Plus I like the modernization aspect of it. I've also installed a mirror that autodims and has a built in garage door opener, the trunk is electric, I made my version of the DSE multispeed wipers, the instrument cluster is from a 95 Camaro so I've got all the gauges working including the warning lights, the windows are one touch electric, and I don't use keys to turn on the car as I built an RFID system. I use a little key fob to activate the car. So the efi fits. LOL.
09-24-2014 #7
