      Dec 2007
      Lombard, IL
      Motor Mounts for LS, small block & big block.
      I ended up with a few of the wrong mounts for a couple different projects.
      Prothane 7-504-BL
      These are the prothane early style “short and wide” mounts for big block & Small block Chevy.
      This is the early style "short and wide" motor mount that measures 2 5/8 in. between the ears and 1 3/4 in. tall to the center of the through bolt hole.
      I won’t try to say what these fit. If you know, ya know!!
      These were never bolted on.
      Summit price is $73.77 so $60 delivered in lower 48
      http://www.summitracing.com/parts/ptp-7-504-bl
      Energy Suspension 3-1150R
      LS engine adapter mounts
      These are the later tall and narrow mounts.( 2 3/8 in. x 2 3/16 in) Locates the bellhousing mounting flange approximately 1 in. further forward than the standard small block location (from catalog).
      Someone was confused and hit the grinder to one spot on the plate (see photo).
      These were bolted on for mock up only.
      Summit Price $115.97 so $95 delivered in lower 48
      http://www.summitracing.com/parts/ens-3-1150r/overview/
      Located in Lombard, IL
      Six30-77two-382five
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
