      Aug 2010
      Los Angeles
      Would this accessory drive work?
      Installing an LS3 in my 68 Camaro and was curious if it would play nice? I've got a DSE subframe if that helps? It's hard for me to justify paying $2k for the front runner setup.
      http://paceperformance.com/i-6485405...7-engines.html
      Las Vegas, NV
      Quote Originally Posted by spacepirate View Post
      I am sure that it will
      I am running that same accessory drive on my 68' with stock sub, with not fitment issues
      Jeff
      Apr 2012
      Woodstock, IL
      I agree, the power steering pump is high enough to most likely not interfere with the steering shaft too. The serp kits that are more problematic with fitting are ones with the AC compressor down low, and/or the alternator being low. These can often interfere with engine mounts and the rack fittings.
      -Dale
      SchwartzPerformance
      Jacksonville, FL
      Have you tried calling DSE? I am sure they could tell you for sure.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Aug 2010
      Los Angeles
      Thanks everyone! I haven't spoken with DSE yet but I will contact them. I just wanted to see if anyone else had used this setup.
