    Results 1 to 20 of 30
      Tallahassee + Seminole, Florida
      Aftermarket first gen subframe - $1800??
      Hey everyone,
      Thanks for putting up with me. In my midnight wanderings on eBay, I found this: Subframe
      It consists of Mustang II suspension, rack, and QA1 Aluma-Matic Coil Overs... with SFCs and tranny crossmember, and brakes for $2250.
      Now subtract the brakes, and add Proma-Stars and you got $1800.
      It looks a lot like the Fat Man subframe... does anyone have any idea about how this would handle? I know its no Corvette suspension, but right now I have DS&E's Speed Kit 1. How do you think it would compare to that?
      It seems like a pretty decent deal. For those too lazy to visit, I'll copy the description over here:
      Upgrade your stock front-end with a direct bolt in frame. This front-end will increase the room in your motor bay, reduced front-end weight and improve your ride down the road or track. Our jig welded frame has stock location body mounts, stock transmission cross-member holes, stock core support mounting holes, stock bumper mounting holes. The frame utilizes tubular control arms, Mustang II Spindles, 11” vented rotors, Mustang II rack, screw in ball joints, QA1 Shocks and Spring, checkout below for a complete list of the standard features:
      • Direct Bolt In 2" x 3" Front Clip with Body Mounts
      • Fully Jig Welded
      • Upper & Lower DOM Control Arms
      • QA1 EXF Rod Ends with Teflon/Kevlar Races on Upper and Lower Control Arms
      • Mustang II Rack with Tie Rod Ends
      • QA1 Aluma-Matic Coil-Over Shocks
      • QA1 Springs (Your Choice Of Rate)
      • Screw-in Ball Joints
      • Mustang II Spindles
      • 11" Vented Ford Brake Rotors
      • GM Calipers & Brake Pads
      • Adapter Caliper Brackets
      • All Bearings, Seals, Dust Caps & Mounting Hardware
      • Motor Mounts
      • Steering Joints & Shaft to Hook-Up the Stock Column
      Frame Rail Connectors
      Options
      • Drop Spindles - No Extra Cost
      • Credit for no rotors, calipers and caliper brackets - $525.00
      • Upgrade to QA1 Proma-Star AL Shocks - $75.00
      Upgrade to Wilwood Disc Brakes (not available on drop spindles) - $275.00
      Thanks for your imput!
      Max
      IL/TN
      how thick is the frame material?, no anti-dive built in, IMO it's fine for a drag car but not a touring car.
      https://www.protouringf-body.com "doing what they say can't be done"
      Quote Originally Posted by 79T/Aman
      I don't know how thick the frame is. They're not open on Saturdays, and I was just wondering if anyone had any experience with them. I figured the MII suspension would offer better handling than a stock sub, and maybe even the DS&E upper arms.
      Plus, everything is new, including the rack. So, at that price, its not bad.
      If anyone else has any imput, feel free to correct me
      Max
      Mar 2002
      Redwood City, CA
      In all honesty, it looks like a drag setup to me, but who knows. I think it would handle ok.
      Although..... It makes no mention of any sort of sway bar. Also, the Mustang II is more of a hot rod retrofit than a real performance handling setup. The DS&E stuff on a stock subframe will probably outhandle that one.
      Allen Ortega
      Quote Originally Posted by zbugger
      Yeah, thats what I figured. I thought it was wierd that they didn't say anything about a sway bar.
      Oh well, it was a nice thought. I can't cough up enough money for a good C4 or C5 subframe, so I went with the tubular uppers. But $1800 looked mighty appealing, especially with the rack.
      Thanks everyone!
      Max
      Apr 2004
      OKC, OK
      Quote Originally Posted by madmax
      Max
      You would be much better off with a full DSE conversion. Go out and measure your stock sub rails. 50%-60% larger. MII stuff isn't associated with handling, more for parking lot cruising.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Quote Originally Posted by MuscleRodz
      Mike
      Unfortunately, the full coil-over is out of the question as of right now. I just can't cram that into the budget, so I got their tubular uppers, sway bar, and shocks. I was wondering if the MII would offer better handling than that.
      -Max
      IL/TN
      the MII or pinto set ups were addopted for drag racing for their lighter weight and were never designed to be used on heavier cars and take the side loading that a touring car can do, especialy with today's tires
      Jan 2003
      Arizona
      Max,
      MII suspension is popular on street rods because it's commonly available and cheap. No one ever said it was good--just better than what came stock on a 1939 Ford.
      From the pix, it looks like someone took a typical aftermarket street rod MII kit (crossmember and suspension parts) and built some frame rails around it. For your money, you'll probably get a car that handles, well, like a street rod. While the price is right compared to popular performance clips. I wouldn't touch that clip unless:
      A: I saw it installed in an actual car or two. It may look okay lying there on the floor, but "bolting it in--headers, drivetrain alignment, wheel backspacing, etc. is a whole different ballgame. Who knows what kind of problems you may run into during the install.
      2: You drove a car that has that clip installed, or got a sparkling reference from someone you know who has (i.e. a P-T member).
      If that doesn't turn you off, note that the crossmember welded at 90 degrees to the frame rails with no additional triangulation. Again--pure street rod.
      But the most important thing to know is that upgraded stock clips work very well. So play it safe and keep upgrading what you have. Upgraded parts are tried and true. And they're about to get even better!!
      ________________
      Steve Chryssos
      Apr 2004
      OKC, OK
      -Max
      tubluar lower a-arms......$575
      coil over kit..................$475
      coil over shocks............$560
      coil over springs............$110
      total..........................$1720
      less jig return.............- $50
      total..........................$1670
      You said you already have the DSE upper arms and sway bar. Unless my math is wrong how is the DSE setup out of you budget if you are looking at an inferior $1800 subframe? DSE parts are $130 less plus the DSE parts will be cheap to ship in comparison to the sub.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Mike
      Well, if this sub had worked out I would have sold the DSE stuff I already have. So, the math with DS&E and a rack would be:
      Uppers: $650
      Lowers: $575
      Coil Kit: $475
      Coil Shocks: $560
      Coil Springs: $110
      Jig: -$50
      Rack $800
      Shipping: About $100
      =$3220
      PLUS whatever a shop would charge to modify the frame for the coil overs, since I can't do that kind of thing myself. A couple hundred? I don't know how many hours it would take but It seems like it is pretty involved.
      Other frame:
      Frame: $1800
      Shipping: $150
      = $1950 vs. about $3420
      That is pretty significant in my book... but it seems that this set-up would not handle well at all.
      I know the DS&E parts are vastly superior to the MII stuff, but I thought it was a way to save nearly $1500 - which I can't afford at the moment. So basically this was a breakdown of the parts I have now vs. this rack which is:
      Speed Kit 1 (Uppers, sway bar, lower bushings, replacement Koni shock and spring): $1299
      Rack: $800
      Shipping: $100
      Total: $2199
      So... the aftermarket sub was $249 cheaper... with coil overs and tubular uppers and lowers (albiet is MII).
      Hopefully that unravels my thought process behind this thinking!
      Thanks for listening to my babble
      -Max
      La La Land, CA
      With our new AFX spindle you'll get as good, if not better handling than the full DSE coil over system, plus it is a direct bolt on. Check it out on our website, you can get outfitted with brakes for under $1k.
      Tyler
      Silicon Valley, CA
      Quote Originally Posted by TitoJones
      Tyler
      great another company JUST making stuff for the stupid 67-69 camaro.
      There are other year camaros out there
      Poor second gen guys
      May 2000
      Quote Originally Posted by 4RS FED
      You already have a tall spindle. What exactly do you want?
      La La Land, CA
      We are making provisions to make our AFX spindle work with the 2nd gens. No more crying about it.
      Tyler
      Mountain View, CA
      Hey, you have a much better platform to start with. Be glad you aren't one of us masochists trying to cram our square pegs into round holes.
      True T.
      My blog
      Jun 2002
      Benicia, CA
      Approximate cost?
      Tyler
      How much will the 2nd Gen spindle and hub assembly cost? I 'upgraded' to a B-body spindle already but haven't got the hub part ironed out yet. If I cannot use the 3rd Gen hubs I have (still have to machine them) I will be looking to find something different.
      Jeff
      1971 RS Camaro: PAINKILLER
      Silicon Valley, CA
      Tyler
      when you figure it out, please let me know so i can buy a set
      Nov 2004
      NW Arkansas
      Quote Originally Posted by MarkM66
      KENNY DAVIS HOTRODS
      May 2000
      Quote Originally Posted by jeffandre
      What is the benefit from putting a B-body spindle on a Second Gen?
