    Thread: Question?
      Jan 2014
      Okinawa, Japan
      Question?
      I have a base model 1980 firebird with upgrades to the drivetrain and I would like to increase my stopping power with the lowest cost to my pockets. My question-Can i achieve this goal by upgrading stock front disc with larger rotors and larger calibers? Can I get by with this without changing the boosters? If so, what type or style do you recommend that is low cost to my pockets? In the future I would like to convert the rear drum to disc but for now I want to focus on the front. I do believe I have a size 11 in rotors on the front, i hoping to increase the size to 13in. Thank you in advance for your assistance! Any input you can provide would be deeply appreciated.
      Silverbk84
      The least cost option would be to install and bed some good brake pads. Something along the lines of StopTech Street Performance pads are a good choice.
      Bob.
      Jan 2014
      Okinawa, Japan
      Thanks Bob!
      Jun 2006
      Katy,TX
      Any bigger rotors up front is generally going to need a larger wheel. The B body spindles for 12" (actually about 11.88) rotors can fit a 15" wheel. Using a late 80s early 90s Camaro 1LE rotor(or redrilling a B body rotor for 4 3/4 bolt pattern) will give you a little bigger rotor that can fit a 15" wheel if larger are not in the budget yet. That and a good pad.
      The 96 Impala "police" D614 pad is larger that the stock D52 pad and will fit the caliper and can be used even on the stock 11" rotor. I know Hawk makes a D614 pad so they are available in a good pad. So as a67 said a good pad will help as well as soem good shoes. When I was running disc/drum with semi metallics back in the day I could still lock up the rears on heavy braking so an adjustable prop valve in the rear line can help tune in your system.
      There are also companies that make a better performance drum compunds if you are keeping those.
      1965 GTO project car
      2004 Pulse Red GTO
      Jan 2014
      Okinawa, Japan
      I will try this, thanks for your help.
      Aug 2012
      Peoria, AZ
      I'm running EBCYellowstuffR brake pads on stock 10.5" rotors and a 2.75" single piston caliper and my car stops like crazy. The EBCs are a great street pad plus when it gets hot on the track it really starts to grip.
      Lance
      Oregon
      The easiest way to increase brake torque (stopping power) is to run a higher CoF compound pad, as suggested above. The easiest way to add brake capacity would be to increase rotor size, diameter and/or thickness. Given the application, you could opt for Skip's suggestion to swap over to a 12" nominal GM tall spindle and inherit the bigger brakes along with it, however given your location of Japan, that's probably not going to be as simple as heading down to a local wrecking yard.
      What's the intended use for the car?
      Tobin
      KORE3
      It's what I does.
      Jan 2014
      Okinawa, Japan
      My intentions is for street use on the weekends and possibly so track action. Thank you for your input.
