    Results 1 to 1 of 1
      Jun 2006
      Katy,TX
      Second gen F body upper control arm weights
      Thought I would post some info for you weight conscious folks. All are with ball joints and bushings.
      Global West Drag arms 6lb 10.5oz
      Pro Touring F body 7lbs 8.5 oz.
      stock stock rubber bushings 9.0 lbs
      Global West regular arms 9lbs 2.5 oz
      The Global and stock arms have the ball joint mount slightly canted from the axis of the cross shaft, whereas the PTFB are straight as soem othe aftermarket arms are.
      1965 GTO project car
      2004 Pulse Red GTO
