    Page 2 of 2 FirstFirst 1 2
    Results 21 to 21 of 21
    1. #21
      Des Moines, IA
      Ok guys. . .
      As it sits right now here's the kit:
      Front Upper Control Arms:
      -two self lubricating Delrin bushings per arm
      -two "dogbones" per arm (these are straight CNC-ed trunnions that are slotted. . .I'll look into offset later as I need to make sure the arm will not contact the frame when pushing the arm inward)
      -four washers per arm
      -4 snap rings per arm
      Front Lower Control Arm:
      -two "small" bushings for the forward mount
      -two "large" bushings for the rearward mount
      Bushings are direct fit into OE control arms:
      -no machining required
      -no lubrication zerk required
      Complete kit for the front will be right at $500.00
