    Results 1 to 9 of 9
      May 2014
      I almost crapped my pants
      So im driving down the road and happened to look down and noticed the temp gauge buried in the meltdown area. I pulled over only hitting 2 people and a dog and shut down the engine. After opening the hood, first thing i noticed is there is no smell. Whenever i have been around an overheating car you can smell it. Also the engine just didnt seem that hot. I went ahead and took a chance and drove it the rest of the way home and put a temp gauge on the engine and it was only 160 after being shut off for like 3 minutes. Obviously not overheating.
      Heres the question. My temp gauge doesnt start at the cold part it starts in the middle. I dont think thats where its supposed to start?. Does this seem like a faulty gauge or a bad sender?
      This is the factory gauge in the pod on the center console.
      Thanks in advance
      1969 Camaro 572ci BBC, Built T350, Flowmaster headers, Foose wheels
      Feb 2014
      I would start by replacing the coolant temp sender. Maybe it's getting old
      86 Monte Carlo SS
      @corybrowning19
      Jun 2013
      x2 ^
      Feb 2014
      Also, when ordering/picking up a new one, there's often 2 part numbers that are off by a "P" at the end. Once will be a buck or so more. The difference is the more expensive one has a nice leak proof sealant on the threads. Much more durable than teflon tape. Worth the $1!
      86 Monte Carlo SS
      @corybrowning19
      May 2010
      kitchener,Ontario,Canada
      Check the thermostat as well. And when you fill the system back up make sure the heater is turned on you can actually create a air bubble...aka lock in the system if the car isn't up to temp with the heater on.
      Ryan Austin
      On Instagram ryanaustinss70
      Jonesboro, Arkansas
      If it continues, look at possibly a ground is missing somewhere. My fuel gauge didn't read right and the sending unit wasn't grounded good enough.
      Carl Wilson
      Sep 2011
      Whitehall,Pa
      Hope the dog was okay...
      Mar 2011
      Ca
      I had a temp gauge do this once and it was a wire that went to ground when a braded line cut the housing.
      Apr 2013
      Marina Del Rey, CA
      What kind of gauge is it? Factory? And what kind of sensor are you using.
