    Page 16 of 23 FirstFirst ... 6 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
    Results 301 to 320 of 441
    1. #301
      Nov 2010
      The bed is outside, got the chassis stripped, I have to flip it over, finish welding, then a couple coats of SPI black epoxy.
    2. #302
      Jan 2015
      los angeles CA.
      Nice work retaining the patina
    3. #303
      Nov 2010
      Might seem crazy, but I finished the body work on the chassis, really want it to look nice from underneath. I'm thinking a couple coats of SPI black epoxy will give it a nice matte finish. Also had my sway bars powder coated.
    4. #304
      Having seen the Dart, I expect nothing less. It's going to be sweet!
    5. #305
      Nov 2010
      Thanks Wayne
    6. #306
      Nov 2010
      So I picked up a cheap Ebay scale so I could weigh some of the components, just out of curiosity. The chassis came in lighter than I expected at 480Lbs.
      The engine and trans together came in at 770Lbs , and the Dana 60 was 275lbs. I don't know if these or good or bad (doesn't really matter) anybody have any weights for comparison?
    7. #307
      Aug 2002
      Waleska Ga.
      Looking Good !
      I think the weight will be what it is! as you said , its where you put the weight that maters most!
      Keeping the weight as low as possible and trying to get it as close to 50/50 bal. is key!
      cool project!
      David Sloan
    8. #308
      Sep 2013
      sw Kansas
      Your weights are correct as what I have seen. I want to caution you about something. All ceramic insulation only does so much. It;s pretty good at sound deadening but heat transfer is not where it accels. I use a product called Low E insulation. There are many places to buy this product. It's thin and easily glued to all surfaces. I have used it in the last couple of hot rods I've built. Your truck has enough area in the cab that a good ac unit such as Vintage Air will do a good job but on a tight confine builds such as a 32 Ford, you will need all the insulation you can get. Thickness always causes problems. Your project is looking good!
    9. #309
      Nov 2010
      Thanks for the tip....
    10. #310
      Nov 2010
      Got the rear end prepped, 2 coats SPI epoxy primer, Then 2 coats Kirker Hot Rod Black to get the perfect matte finish.
    11. #311
      Nov 2019
      Quote Originally Posted by Tincup View Post
      Awesome build, love the approach and skill set demonstrated here throughout. Very inspiring. Got to the end of the write up to find it still being actively worked on!
      Joined the forum just to give you a big and sub'd.
      -Derek
    12. #312
      Nice job on the prep work, the paint came out great.
    13. #313
      Nov 2010
      Quote Originally Posted by DocME View Post
      -Derek
      Thanks Guys...
    14. #314
      Nov 2010
      Final assembly has begun, back is done except for the calipers, which i'm prepping for powder coat, with my new Eastwood powdercoat system. Name:  20191113_181146.jpg
    15. #315
      The frame came out nice. You‘ll have to let me know how you like the Eastwood kit.
    16. #316
      Jun 2017
      Edgewater Co.
      I got a hotcoat gun recently, it's a little odd having to press the button with one hand and shoot with the other but the results are worth it...
      20191031_165405 by Joseph Martin, on Flickr
      These are wheels I've done for my RV project, the just barely fit in the oven I got for free. For colors, you need to go to Prismatic Powders, there selection of colors is mind blowing... There are a lot of things that I used to rattle can that will get coated now...
      Joe
    17. #317
      Nov 2010
      Quote Originally Posted by Motoracer838 View Post
      Joe
      Thanks Joe, I did a couple parts today, There's definitely a little bit of a learning curve, but your right, no more spray bombs.....
    18. #318
      Jun 2017
      Edgewater Co.
      One thing I've found out that I like, preheating the part and shooting while still hot ( aka "hot flocking" ) seems to give me better results and uses less powder. Hot flocking also allows coating of non conductive items like glass.
      Joe
    19. #319
      Nov 2010
      Joe
      I've seen that mentioned, and thought it was a good idea. But I guess you can actually get runs that way. I'm gonna try it....on some scrap..
    20. #320
      Sep 2019
      Colorado
      Awesome build!
      I love the power plant and attention to detail!
      Looking forward to seeing this one on the track! Thanks for sharing!
      - Jerry
