    Page 59 of 80 FirstFirst ... 9 49 54 55 56 57 58 59 60 61 62 63 64 69 ... LastLast
    Results 1,161 to 1,180 of 1589
    1. #1161
      Apr 2014
      Quote Originally Posted by All4rocks View Post
      Looks Nice! what kind of camera do you use to take these pics?
      iPhone 10 for the last two years and since this past November an iPhone 11.
      Thank you!
      Pat
    2. #1162
      Sep 2012
      Dang i need a new phone!
    3. #1163
      Dec 2011
      Country Flag: Netherlands
      Very nice and clean Pat, as always.
      Did you put anything on the back of the relays to keep them from resonating against the core support?
    4. #1164
      Apr 2014
      Quote Originally Posted by V8livin View Post
      Yes sir! 1/16" foam double stick tape.
      Thank you!
      Pat
    5. #1165
      Quote Originally Posted by keepat View Post
      Weld Mount is in acrylic adhesive mounting system with a wide variety of very cool fasteners. We use it on the boats when we cannot drill into a bulkhead, fuel tank, or hull sides to mount or fasten equipment and wires. I used it to mount a few fan relays and headlight door operator To keep the engine bay clean of fasteners. Very cool stuff, easy to use an extremely strong!
      Pat
      http://weldmountsystems.com/
      free image url
      image sharing
      common american girl first names
      Awesome stuff. I ended up going down a rabbit hole and found this:
      www.clickbond.com
    6. #1166
      Apr 2014
      www.clickbond.com
      Very similar product but they have a lot different fasteners thanks for sharing!
      pat
    7. #1167
      Apr 2014
      With the battery being relocated to the trunk and needing a few direct to battery power connections I made a breaker/switchbox to be located in the trunk. The 12”x 9” box holds a remote battery disconnect and starter solenoid. It also has a series of breakers for the alternator line, dash power, subwoofer, fuel pump, fuel injection, and a few other low amperage items. I still have a few details to work out, then disassemble the box and paint it black along with labels for the breakers before I install it.
      Pat
      multi photo hosting
    8. #1168
      Sep 2013
      sw Kansas
      Is this also an anti theft devise?
    9. #1169
      SF Bay Area
      Interesting solution. Is this box something you built or are they available off the shelf?
      Also, intrigued about using circuit breakers instead of fuses. Do they wire up the same as a fuse (inline)?
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    10. #1170
      Apr 2014
      Quote Originally Posted by chunger View Post
      No, I made it for the car. Someone may make one off the shelf??
      Breaker and fuses install the same way and do the same thing, (protecting the line) the advantage of the breaker is it is quickly reset as well as disconnected.
      Pat
      - - - Updated - - -
    11. #1171
      Apr 2014
      Awesome build ,very very nice , it must feel great to be in final assembly. I am hopefully going to be in final assembly in six months your project is a great motivator nicely done
    12. #1172
      Apr 2014
      Quote Originally Posted by Dragonfly View Post
      I will hold off from calling it the final assembly as not to jinx the final assembly ;-)
      Pat
    13. #1173
      Apr 2014
      Trunk mounted battery and breaker box installed. I still have a lot of wiring to do but making progress.
    14. #1174
      Sep 2013
      sw Kansas
      Am I correct in seeing there is a manual override in case of remote failure?
    15. #1175
      Apr 2014
      Yes it’s a very cool battery disconnect switch that can be operated both electrically or manually we use them on the yachts we build and sell.
      Pat
      https://www.bluesea.com/products/770..._-_12V_DC_500A
    16. #1176
      May 2009
      That's a great idea, and BlueSea makes quality components.
    17. #1177
      Apr 2014
      Made some progress with most of the wiring under the dash and installing the dash along with all the AC ductwork. And put some fuel in the tank so I wouldn’t accidentally run the in tank fuel pump dry. Hope to have it running in 3 or 4 weeks.
      Pat
    18. #1178
      Wow amazing progress. It looks great. You at the boat show?
    19. #1179
      Apr 2014
      Good memory! I fly down Wednesday.
      Thank you!
      Pat
    20. #1180
      Sep 2013
      sw Kansas
      Race gas. Under the dash always gets full. You build a bigger car, you put more stuff in. I like your floor mats. I may invest in some.
