    Page 6 of 80 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 16 56 ... LastLast
    Results 101 to 120 of 1589
    1. #101
      It Looks good.
    2. #102
      Apr 2014
      The Plasma cutter and spot weld cutter make short work of removing the right side inter wheel well. It would nice if it goes back in as easy, wishful thinking!
      Pat
    3. #103
      Apr 2014
      I test fit the 4 link rear today and put the rear wheels on the car for the 1st so I can setup the inter wheel wells. It’s not quit the milestone of a car coming out of the paint booth, but seeing it with the wheels on and the right stance is a close 2nd!
      Pat
    4. #104
      Nov 2009
      the dirty mitten
      Killer stance! Looks great with all of your progress! How did you make that slit in the rear frame rails for that brace before the shock mount went in?
      Steve
    5. #105
      Oct 2010
      Rockaway. NJ
      Oh my...... that is nice
      Troy
      67GTO
    6. #106
      Apr 2014
      3/16 drill bit on the top and bottom and then I used a Dremel with a cutoff blade to cut between.
      Thank you!Pat
    7. #107
      Apr 2014
      Before the new trunk floor gets installed I moved the wheel well flange in 2 ¼” on each side to keep an original look to the floor.
      Pat
    8. #108
      Jan 2015
      Charlotte, NC
      Can't wait to see those two chase eachother around the yard!
    9. #109
      Nice!
    10. #110
      Jul 2013
      Gilbert, AZ
      Oh wow. That's killer.
    11. #111
      Apr 2014
      Remove what was left of the trunk floor and cut some dead weight out of the frame by removing the rear spring mounts. I also removed the left side trunk drop to do a little rust repair that I found when the trunk floor was removed. I could’ve bought a new trunk drop but I enjoy saving as much of the original steel as I can.
      Pat
    12. #112
      Nice job. It looks good.
    13. #113
      Apr 2014
      Out of town for a few days working at the Miami boat show, but got back on the Charger this weekend. Remove most of the paint, undercoating, and surface rust in the trunk.
      Pat
      Heat-gun and a putty knife and then wipe down with lacquer thinner makes quick remove of the original sound deadening.
    14. #114
      Aug 2011
      North Platte,NE
      Very very skilled progress, im super impressed!
    15. #115
      Dec 2007
      Lombard, IL
      I really like this build; so so very cool.
      Are you going to be able to slide that trunk floor in thru the back seat area?
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
    16. #116
      Nice job cleaning it up in there. What are you going to put back in its place for sound deadening?
    17. #117
      Apr 2014
      Quote Originally Posted by Zanie View Post
      Yes with the inter wheel wells out and the package tray cross braces removed it will go in from the back seat area.
      Thank you!
      Pat
    18. #118
      Apr 2014
      I'm not sure yet as I'm not sure how I will finish the trunk (stock or custom?)
      Thank You!
      Pat
    19. #119
      So. Cal
      Looks great. Glad I found this thread. Cant wait to see the car completed!!
      Shaun
    20. #120
      Nov 2009
      Manitoba, Canada
      Looks awesome. Can't wait to see the end result, always loved these cars.
      Evan
