Page 55 of 57 FirstFirst ... 5 45 50 51 52 53 54 55 56 57 LastLast
Results 1,081 to 1,100 of 1131
  1. #1081
    Apr 2014
    Install the brake and clutch master cylinder and pedal assembly today.
    Pat
  2. #1082
    Feb 2014
    WOW!
    Looks like you poured a clear epoxy over everything. Looks like a show car!
  3. #1083
    Apr 2014
    Quote Originally Posted by Bob in St. Louis View Post
    WOW!
    I’ve had my fair share of spills but none of them have turned out quite well ;-)
    Thank you!
  4. #1084
    Sep 2013
    sw Kansas
    Have you had a hydroboost before on anything you owned?
  5. #1085
    Apr 2014
    Yes, on a few new trucks.
  6. #1086
    SF Bay Area
    I'm curious about your clutch master cylinder mounting. Is that a kit or did you decide to mount it very low? I see you don't have much space where it would mount horizontal, looks like your link lock is there. How's the geometry work for this? It might be the angle of the picture, but it seems that when the clutch pedal is depressed, the rod is going to swing in a wide arc that wouldn't be aligned with the master cylinder anymore. Wouldn't that cause the cylinder to wear quickly?
    chunger
    '68 Ranchero 500
    '70 Cougar XR-7 Convertible
    '98 Mustang GT Convertible
  7. #1087
    Burbs of Detroit
    Something's been bugging me- image 2 post 1081- is the line with the regulator the feed or return? Is the regulator an Aeromotive 13129 type?
    My brother had a similar setup with a similar regulator plumbed roughly the same way it looks you plumbed yours. It turns out that he had incorrectly plumbed the regulator, he had assumed the bottom of the regulator was the feed, and the side ports the outlets, as many other regulators. When plumbed with the bottom inlet, the regulator did not work correctly.
    If I am mis-understanding how you plumbed the regulator, I apologize.
    Greg Fast
    1970 Camaro RS Clone
    1984 el Camino
  8. #1088
    Apr 2014
    Thanks for the heads up it’s been a few years since I put those lines together I will follow up and check the flow!
    thank you!
    Pat
  9. #1089
    Apr 2014
    I double checked my plumbing diagrams from a few years ago and also confirmed how I have it on the car and it is correct the regulator is connected to the return line and plumbed hell the Aeromotive manual suggest.
    Even though I had it correct it’s always nice to double check things!
    Thank you!
    Pat
  10. #1090
    Burbs of Detroit
    Good- it was impossible to tell from that image what the actual condition was. Figured it was better that I raise a potential flag, glad to see I was wrong.
    Brother had it plumbed opposite- Regulator was on the feed side, caused him to struggle for a couple weeks.
    Again, i love the build
    Greg Fast
    1984 el Camino
  11. #1091
    Dec 2018
    Country Flag: France
    The plumbing looks gorgeous.
    Maybe you already answered that somewhere but did you paint the underdash a lighter color to make it easier to work on the car once everything is reassembled?
    Everything can be fixed with a big hammer.
  12. #1092
    Apr 2014
    Quote Originally Posted by chrisp View Post
    originally Mopar never painted under the dash so it was raw steel so I wanted to replicate that look and at the same time keep it light so it wouldn’t be so dark under the dash when you have to work on it.
    thanks
    Pat
  13. #1093
    Quote Originally Posted by keepat View Post
    thanks
    Pat
    Brilliant thinking.
  14. #1094
    Apr 2014
    Installed the quarter extensions and the shaved & shortened rear bumper.
    Pat
    host pictures
  15. #1095
    Feb 2014
    Where did you have the chrome work done, and if you don't mind me asking, how much did it cost (and for what pieces).
    Just spectacular!
  16. #1096
    Apr 2014
    Just spectacular!
    Paul’s Chrome in PA has done all the chrome on all of my cars.
    Been two years since I’ve had them done and I don’t remember the price but I do know they’re not cheap, but you do get what you pay for!
    pat
  17. #1097
    Feb 2014
    Thank you.
  18. #1098
    I agree with 68Formular. A simple idea but a great one. The bumper look nice on there
  19. #1099
    Apr 2014
    it’s a small change that enhances the appearance without drastically changing the look of the car
    Thanks!
    - - - Updated - - -
    Starting to look like a 68 Charger!
    Pat
  20. #1100
    Sep 2013
    sw Kansas
    Who helped install the bumper? Do you have a method to do that by yourself?
