      Aug 2010
      New Albany IN.
      bead rolling for strength
      I posted this in another section and then figured it would be better here. I am currently making an air dam and then I am going to make a nascar style rear spoiler with the piano hinges and adjustable supports. I already had a sheet of 16 G aluminum and I can already tell it's to thin the way it is. I was wondering if it would be strong enough if I added bead roll to it? If not what thickness should I look for
      California
      Bead rolling would add a decent amount of strength to the part, but if you paired the bead rolling with additional supports and proper designs it would be a significant increase.
      Aug 2010
      New Albany IN.
      Thanks. It will also be supported by heavy duty piano hinge at the bottom and support rods at the top. I'm even thinking about adding a 1 inch lip on the top that is bent towards the rear of the car
