    Results 1 to 14 of 14
      Oct 2013
      18x10 with a 295?
      Will a 18x10 wheel with a 295 tire fit a stock second gen with no mini tubs that has a 2 inch drop? I know this has probably been asked 100 times but just want to be sure thanks.
      Apr 2008
      That's what I have on mine exactly. Mine is 3" lower in back. No problems. I will try and find an old pick. Car is on blocks getting a new motor right now
      Mike A
      69 Chevelle
      496 Big Block
      Apr 2008
      In fact my next set I'm gonna try 305's because of how much room I have. I run nitto's right now though and they tend to run a bit narrower from my experience. Also I am running a short tire. 295/35/18. Next tire I'm gonna try is 305/40/18. I do have the lip rolled which helps a little.
      Mike A
      69 Chevelle
      496 Big Block
      I have 295/30/19 on mine. No rubbing with BFH mod to seat belt hump and rolled lip
      Knox Vegas
      We're just talking rear wheels/tires here, right?
      ~Tony
      My Car: 1972 Mustang Mach 1
      . It's a decent roller, and that's about it, for now. Gotta start somewhere.
      Oct 2013
      Quote Originally Posted by Knoxferatu View Post
      yes but hey I'd like to hear what front tire size everyone is running as well
      Knox Vegas
      Quote Originally Posted by 71maroesteban View Post
      Yeah, that's where I was headed next. I expect most are able to fit a 245-265mm tire without some kind of minor accommodations. I'd love to fit same-size 18x10's with 295's at all four corners on my Mach 1, but I know it will require some work.
      ~Tony
      Apr 2008
      In the front I run 265/35/18 on a 18x9 wheel. I have a large sway bar and it hits at full lock. I also had to make some minor mods to the lip of the wheel well. Overall fits pretty good and could probably do a 275 with a little more massaging. Car is lowered atleast 2" in front if not 3"
      Mike A
      69 Chevelle
      496 Big Block
      Quote Originally Posted by 69496 View Post
      Would Luv to see a pic if u can. I would like to have my wheels widen in the future to fit a 265
      Apr 2008
      I will look. I should have some. My car is sitting right now without the motor because I'm switching from a 383 to 496 so the ride height is off but I should have some pics saved somewhere. Worst case I will take some pics as it sits now and then post new ones after I get the motor in.
      Mike A
      69 Chevelle
      496 Big Block
      Apr 2008
      Not the best pics. Car isn't on the ground and has no motor. I lost my good photos of car running when computer crashed. Anyways. 18x9 front 265/35. 18x10 back 295/35. Need to start a build thread.
      Mike A
      69 Chevelle
      496 Big Block
      Apr 2008
      Sorry pics are sideways
      Mike A
      69 Chevelle
      496 Big Block
      Apr 2008
      Found some older ones. Sorry for the dusty car.
      Mike A
      69 Chevelle
      496 Big Block
      Knox Vegas
      Looks you nailed the fit. Nice.
      ~Tony
