      May 2013
      L&H Kustoms (Pro Billet) spindle problem
      First, I have been told that L&H is no longer in business, so if that is incorrect please let us know. I haven't had any luck making contact.
      I need to find the replaceable upper inserts for the L&H spindles that will fit the 74 up (tall spindle) Camaro K5208 ball joint instead of the 64-68 Chevelle K5108 ball joint. Does anyone know of a source for these screw in aluminum inserts?
      If that is impossible, I'm faced with changing out the ball joints in Global West upper control arms. Those ball joints are from a mystery application and are welded in. Sure would be great to find those spindle inserts instead. Any help appreciated.
      Apr 2010
      Pittsburgh, PA
      Website seems to be missing, get default BlueHost page..
      Nothing about closing on their Facebook page
      call up Mark From SC&C, he'll know since hes a redistributor of their products too
      72 buick skylark
      Southern Indiana
      Ever look into Howe buildable ball joints in the way of mixing and matching parts? Just a possibility.
      Lee Abel
      AFTERMARKET PERFORMANCE
      St George Utah
      The only person that will have the specs and dimensions for the inserts is L&H. I would think.
      if you can get them out a good machine shop should be able to replicate them with the correct taper
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
