    Results 1 to 7 of 7
      Feb 2008
      Chicago
      Setting vent window glass
      Hey guys
      I need to install new vent glass into their chrome frames and was wondering on the best method. I've done a search a found a couple of guys recommending RTV over setting tape. I've never used setting tape so I don't know how easy or difficult the process is. The RTV sounds simple enough but when I test fit the new glass I find there to be a lot of side to side play. If I used the RTV would I try to center the glass in the frame while the sealant cures or push the glass closer to the interior or exterior side??
      Ken
      Ken B.
      65 GTO
      67 Firebird vert
      May 2006
      Barrington, IL 60010
      The tape (or sometimes rubber) serves as a shim to alleviate the movement you are experiencing.
      Rich
      'Wicked Witch'...1969 Camaro, Mast Motorsports LS-3, Magnum T-56, DSE suspension & BFG Rival-S on Forgeline wheels.
      A herd of stock #'s-matching '69 Camaros.
      Orangevale, Ca
      I used clear silicone on mine with very good success. Gives you ability to get the glass right were you want it and let set up.
      Bret Ervin
      Feb 2008
      Chicago
      It seems like the RTV may be the way to go. Thanks
      Ken B.
      65 GTO
      67 Firebird vert
      I got some setting mateial from a local automotive glass shop to set the glass into the frames on my 57 Chev. It comes in several different thicknesses. You coat the material on both sides with a film of oil which helps with the installation. As the material soaks up the oil, it swells. The extra material is then trimmed of with a razor blade. I was told this was the way the factory did it back in the day.
      Feb 2011
      Indpls, IN
      I also used setting tape.
      I used the setting tape. RTV is nothing but a dirt magnet in my experience and will likely look bad over time.
