    Results 1 to 20 of 30
      Aug 2006
      St. Pete, FL
      17's shoulda bought 18's, tire advice needed
      It really looks like I need a bigger tire in the rear.
      I have a '69 GTO with 17x 8 x 4.5" front wheels with 255/45x17s (26.1 dia) which is fine
      and 17x 10 x 5.5" with 285/40x17 tires for a dia of 26.0" which is a little too small out back. Tires for the 17" wheels seem more limited than the 18s but I'm trying to avoid having to purchase two new wheels and I rather like the look of some sidewall anyway.
      I see that Mickey Thompson has a 295/45x17 (27.2" dia) available as a Drag Radial but I plan on driving this car quite a bit and even have the occasional Florida rainstorm to contend with so this is probably not a good idea.
      I think 295 is about as wide as I can go...3:73 rear gears and TKO600 tranny.
      Curt
      '69 GTO ragtop, 455 R/A, EFI, TKO600, Moser Trutrac 3:73, Speedtech, Hotchkis, Wilwood
      '64 Lemans ragtop, possible LS project
      '08 Pontiac G8, 546 rwhp
      Monterey Peninsula
      Although a 10.5" minimum width wheel is recommended,I'd think you could run a 315/35 on that 10" wheel and have room to swing it with that bodystyle.
      Yokohama makes that tire and TireRack was recently blowing those out for $98/ea + shipping.Heck...I bought a pair just cause they were cheap,haven't mounted them yet,lol...I plan on squeezing them on a 9.5" wheel,wish me luck.
      Tread pattern may have changed by now...I've had these awhile now.
      www.buickfunnycar.com
      Aug 2006
      St. Pete, FL
      Good Looking Tire
      I did read somewhere that 315s might fit but a 315/35 will still be a 26" or 25.7". I think I need a 27 to 28" to look right.
      Attached are a couple pictures. In the process of some mods now and i expect the rear to sit lower when I'm done.
      Curt
      NY
      Try Using TIRE RACKS data base to find a SUV tire that will fit. They are more car like in the speed rated tires and are available in larger diameters and fairly wide widths. I think the BMW X5 with a sport package had a fairly large tire and are speed rated.
      Good luck!!
      Washington, MO
      Just drop in an inch or so, and the tires will appear larger. I think they're a good size.
      Monterey Peninsula
      Quote Originally Posted by Tony_SS View Post
      After seeing those pictures,I think Tony's right...a 10" wheel always looks good on these cars and you have enought tire and sidewall (I have that same setup on one car),just drop that thing down a hair and you'll fill that wheelwell better.
      Go to www.1010tires.com ,click tire size calculator and punch in the various sizes so you can see how they compare.
      Aug 2006
      St. Pete, FL
      Quote Originally Posted by musclecarjohn View Post
      John,
      I would like to see pics of your car with the same size wheels/tires...
      Curt
      Washington, MO
      I had tried a 275/50-17 but it was too tall of a tire and the 9.5 wheel stretched out too far. With 17" wheels its either 26 or a 28" tire.. They should put a 27" tall tire I think. A 275/45 or a 285/45 maybe? But I couldn't ever find one.
      Aug 2003
      Check this one out
      This one runes 18 X 11 and 18 X 9, 305 / 35 / 18 and 255 / 35 / 18 front
      Lafayette
      im in the same boat....im running a 285/40/17 on a 10inch wheel....i need more sidewall to make it look right...im thinkin about running the M/T 295/45s...i would really like to run the 315s...
      Scott
      Built LTX, TKO600, 12Bolt
      Monterey Peninsula
      Quote Originally Posted by ProdigyCustoms View Post
      Check this one out
      Frank,that is one hot looking '68...sweet job,you nailed that one!
      Monterey Peninsula
      Quote Originally Posted by Marauder View Post
      John,
      Here's my '70 SS454 with the following setup:
      Fronts: 18x9 (5.5" b/s) 275/35's
      Rears: 18x10 (5.75" b/s) 305/35's
      And here it is with 17" American Racing 200S wheels,sizes are as follows:
      Fronts: 17x8 (4.5" b/s) 255/45's
      Rears: 17x9.5 (5.5" b/s) 285/40's
      These 17" 40-series tires have plenty of sidewall,IMHO.
      Apr 2007
      San Ramon, Ca
      Frank,
      That is one sweeeet looking GTO. I love it. Those wheels look just plain awesome.
      John,
      I love your 70 SS as well. As a matter of fact, I love your Camaro's too. Great job. I hope to het there one day.
      Chris
      Chris Lemons
      Aug 2003
      Thanks, but I can only take credit for taking his order and selling him the wheels. Jon (owner) did everything else including endless backspacing research.
      John - do you have any pictures of the Chevelle with 17s from the side, similar to the top picture with the 18s?
      The 305/35/18s are a bit larger in diameter than the 285/40/17s correct?
      Monterey Peninsula
      Quote Originally Posted by Jsapata View Post
      I'm afraid not man,those pics were taken the only day those 17" AR's were on the car and I've since sold them.
      If you go back to www.1010tires.com and plug in those 2 sizes,it'll show you a comparison...just remember that all tire manufacturers construct their tires differently so this tire calculator isn't dead-nuts accurate for all brands.
      Thanks Chris Lemon for the nice comments...
      Aug 2006
      St. Pete, FL
      Wow!
      Both of those cars look great!
      I see that the 305/35R18 Toyo Proxie R888 is listed as being 26.3" dia so it not much taller than the 285/40R17 but they sure look right.
      That's one expensive tire at $370 each at www.1010tires.com
      I didn't see any other that size at Tirerack.
      Do you happen to recall the rear wheel width and OS on the '68 GTO?
      Curt
      Arlington Heights, IL
      What wheels are those on that orange gto? Those things are sick!
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      Oct 2005
      Orlando, Fl
      I say lower it some more and you won't notice it. My rear tires are the same height as the front if not a hair shorter and with the car low I can't tell. A lot is personal preference.
      255/45 front are 25.95
      275/40 rear are 25.63
      Don't mind the beater factor.
      Where are you in St. Pete? I'm over there all the time seeing my family. We should cruise together sometime.
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Aug 2006
      St. Pete, FL
      Quote Originally Posted by stealth71 View Post
      Yeah, I'll mess around with the ride height some. Just got the aluminum heads on and am swapping a 7004R for the Tremec and moving the battery to the trunk so that stance will be changing.
      I'm on the south side of St. Pete near the Bayway and spend a considerable amount of time on the beaches but I think that she'll be in the shop for a few months getting new paint and freshened up. Drop me an email if you are around.
      Curt
