    Results 1 to 3 of 3
      Jan 2014
      Ottawa, Ontario, Canada
      PTFB body bushings/mounts install
      I installed PTFB solid body bushings/mounts. I attached pictures to this thread. I did the install with the 0.5" body drop. So I reversed the bigger and smaller part of the bushing like the instructions explained. Can someone verify the attached pictures of the front one (position 1) and tell me if it's installed properly?
      First picture shows the inside under the hood beside my radiator.
      Second picture you'll need to rotate clockwise 90 degrees. It's the front of the frame seen from the front of the car under the bumper.
      Jun 2008
      Greenwood, Indiana
      That looks perfect to me. I put mine on at standard height but yours looks correct. You won't be disappointed with that upgrade. I think it was one of the single best upgrades I did. Love it.
      Jan 2014
      Thank you tflyboy77. Hope this is the right way. I've seen pictures online and they did not place it this way. They had the bushings in between the body and the frame, and the second part was in the frame. Under the hood was only the big washer. That picture confused me.
