      Oct 2013
      Ct
      12..5 wide rim and mini tubs
      Just wondering using stock frame rails obviosly notched and plated on a 1969 camaro running a 12".5 wide rim with a 345/30/19 tire can it be done with DSE. tubs or do I need to modify the outer wheelhouse also ?
      Also has anybody used the chrisalston chassis works mini tubs they look to be similar to the DSE Mini tubs and what's your experience with them if you have used them.
      Thanks,John
      Apr 2012
      Woodstock, IL
      In our experience the DSE tubs need a little work to fit 335-345 tires.
      I don't have any experience with Chris Alstons
      -Dale
      SchwartzPerformance
      Oct 2013
      Ct
      Thanks Dale
      Oct 2013
      335s will fit no problem, your more than likely need to do some mods for the 345s I think there about a 1/2" wider
