Results 1 to 10 of 10
Thread: Where to get stereo wiring?
09-16-2005 #1
Anyone know a good place online to get stereo wiring supplies? I need to get some RCA wiring to go from head unit to amps, speaker wire, thicker 4 and 8 gauge wire, inline fuses, junction blocks, etc.
Also need opinion on wiring for the amps. I have 2 amps that I'm going to be running, and I was thinking of running 1 gauge wire from the battery to a junction block that will split it off into two 4 gauge wires to feed each amp. Would that be a good plan? Where can I get such a junction block? Do I need an inline fuse on the 1 gauge wire or on each 4 gauge wire?
Next I'm wondering about caps - do I need to run one? I'll have a JL Audio 500/1 amp feeding a single 10W7 sub.
09-16-2005 #2Here is about the cheapest and some nice product too. http://knukonceptz.com/
09-16-2005 #3Sounds like you got a pretty good plan on how to run your amps. You could try and find a "fused Terminal block". As far as running a cap, I used to have a vette with a 12w6 running off of a JL 300/1 started out without a cap but eventually with the type of music my wife was listening to and the amp draw it was putting on the car we installed one. Worked like a champ and really helped out on keeping the sub clean sounding.
You could also look at www.onlinecarstereo.comJustin, 68 Camaro Update:5 speed is in and neighbors are pissed!
09-16-2005 #4
