      Nov 2012
      Sacramento, CA
      Road Course Track Engine: SBC 700+ HP / Nearly New & Less than Half Price
      This is a very developed engine package for a track car or mean street car. It has a very smooth, wide drivable power band. It is not "peaky" like small cubic inch race engines & it is not a torque monster down low that goes flat in higher rpm. It pulls HARD from 3500 rpm to 7500 rpm.
      Makes awesome power in various combinations:
      561 HP with 500 cfm 2-barrel & 1.5 rockers
      587 HP with 500 cfm 2-barrel & 1.6 rockers
      684 HP with 850 cfm 4-barrel & 1.5 rockers
      728 HP with 950 cfm 4-barrel & 1.6 rockers
      When I say it is "nearly new" that is because we replaced everything inside before the final 3 events in full overhaul with dyno runs.
      Here is what is used for 2 seasons ...
      * Dart SHP Iron Block (Light Version) with Billet Steel 4-bolt Main Caps
      * Dart CNC Aluminum 227cc Pro1 Cylinder Heads
      * Edelbrock/Wilson CNC Ported Super Victor Intake
      * Jean Dittmer Turtle inside Super Victor Intake
      Here is what is "almost new" with 3 events on it ...
      * Callies Crank
      * K1 H-Beam Rods & ARP S2000 Rod Bolts
      * Wiseco Moly Coated Pistons
      * ARP Main Cap Studs
      * ARP Head Studs
      * Moly Rings / Low Tension Oil Ring
      * Clevite Moly Coated Race Bearings
      * Comp Cam Drive Timing Belt Assembly
      * Comp Cam Roller Cam with Special Lobe Profiles
      * Comp Cams Roller Lifters
      * Comp Cams Chromoly Pushrods
      * Comp Cams Roller Valve Springs
      * Comp Cams Titanium Valve Spring Retainers & Locks
      * Manley Stainless Intake Valves - 2.080"
      * Manley Stainless Exhaust Valves - 1.600"
      * Yella Terra Shaft Rockers (1.5 ratio)
      * Blueprinted Melling Select High Volume Oil Pump
      * Chromoly Oil Pump Drive Shaft
      * Canton Road Race Oil Pan
      * Canton Pick Up & Windage Tray
      * MSD E-curve distributor
      * Bronze distributor gear for roller cam
      * MSD Coil & Wires
      * Aluminum Race Water Pump
      Notes:
      I run coatings, belt drives & shaft rockers in all my engines. The belt drive reduces the harmonics from the crank (each time a cylinder fires) tremendously. This makes everything in the valvetrain ... and the crank ... last much longer. I run shaft rockers, because it keeps the valvetrain true, with no side loads on the valves. Again, for durability reasons, this makes the valvetrain much more bullet proof * long lasting. Lastly, coatings on the pistons & bearings simply make the engine last longer & have a higher degree of insurance.
      As expected, I will assist the new owner with dialing in the tune & any set-up questions.
      Specs:
      4.145" bore x 3.750" stroke = 405"
      Compression: 13.6-1 for race gas, E85, ethanol or methanol
      Cam profile only discussed with new owner
      Block is not the heavy Little M version. It is 40# lighter. So this is a "light SBC"
      New cost: $27,500
      "Almost New" price now: $12,900 with your choice of new carburetor from list below.
      Holley Ultra HP Carb: 850 or 950 cfm / Gas or E85
      QFT Black Diamond Q-Series: 850 or 950 cfm / Gas or E85
      Ron Sutton
      (916) 834-8051
      [email protected]
      Ships from Southern California
      Nov 2013
      near Charlotte, NC
      Ron,
      Sounds exciting! Cannot wait to see your books.
      Conrad
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      Nov 2012
      Sacramento, CA
      Thanks Conrad.
      Nov 2012
      Sacramento, CA
      I'm open to reasonable offers on the engine. Excellent track car engine or hardcore street engine.
      Nov 2012
      Sacramento, CA
      If you want a killer track engine ... and want EFI ... for the same $12,900 price ... I can outfit it with a new, complete Holley HP Multiport electronic fuel injection system & 48 lb/hr injectors (765hp capacity). See it here.
      Nov 2012
      Sacramento, CA
      Engine sold to a a top race team. Thanks for the interest & kind comments both here & PMs.
