    Results 1 to 11 of 11
      Jun 2010
      Deployed
      1970 Camaro Sub-Frame
      Suprise to me....one of the rubber bushings rotted out one of my frame mounts. Looking for a subframe.
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Wow...84 views and no replies. I suspect people are confusing this "wanted" for a a "for sale" lol
      I know quite a few of you all 2nd genners have DSE frames....where are the stockers?
      Oct 2013
      Your gonna have to most likely settle for a late second gen sub frame the 1970-73 are impossible to find I've tried and they don't make repo ones
      May 2010
      Mooresville, NC
      How bad is the mount, can it be repaired? You can buy the hole repair kit like this:
      http://www.carid.com/1967-chevy-camaro-chassis-frames/goodmark-frames-2020389.html
      Plus, this is another excuse for you to buy a new welder!
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      My 68 Camaro frame rotted out at the firewall mounts. It was an easy fix with some large washers-just welded them in, can't even tell once the welds were finished.
      Jun 2010
      Deployed
      Quote Originally Posted by 71maroesteban View Post
      Research has informed me that the 75-81 frames are different. The rust isn't bad...but I suspect the labor would be more than a replacement.
      Mar 2013
      Boise ID
      I have a 70 that I am getting ready to disassemble for a full PT suspension. Will have a straight subframe for sale.
      Oct 2013
      The differences are that huge and another plus is the later second gens suspension handle a lot better
      Jun 2010
      Deployed
      From what I understand the frame holes are not in the same spot. It physically will not bolt on.
      Oct 2013
      It'll bolt on but you just have to re drill the holes I believe look over at nastyz28 they talk about how to do it
      Vancouver, BC
      I'd recommend fixing what you have, unless you have doubts about the straightness or strength of the welds on the rest of it.
      I too had a rusted-out mount hole (on my Nova subframe), check out my post for how I fixed it...
      http://ls1tech.com/forums/11894174-post163.html
      1972 Nova, forged LQ4 with twin 6466's, T56 Magnum, OEM subframe w/ Speedtech front, Chassisworks gLink rear, Ridetech coils & Wilwoods, with a rear floater in the works --> http://www.ls1tech.com/forums/conver...1972-nova.html
