    Results 1 to 9 of 9
    Thread: LS2 vs LS3
      Connecticut
      LS2 vs LS3
      I am looking at a LS2 motor and was wondering if there are any disadvantages a LS2 has compared to a LS3? i know it is smaller cubic inches but it can still be built to have some pretty good power right? are there any other little things you can think of about a Ls2 swap into a 68 camaro. let me know thanks
      Paul Krol
      1968 Camaro
      Apr 2012
      Woodstock, IL
      LS2 vs LS3
      No disadvantages. If you're building it up from scratch get a crank with a 58 tooth reluctor wheel though.. Then the computer and wiring harness to match.
      -Dale
      SchwartzPerformance
      Connecticut
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      Thank you that is exactley the type of stuff i am looking for, so an aftermarker computer and wiring harness would work with it right. no special pedal or anything?
      thanks
      Paul Krol
      1968 Camaro
      Las Vegas, NV
      It will depend on your "final" engine configuration ( ie DBW or DBC throttle body, intake manifold (map sensor location), maf sensor type, cam sensor/ knock sensors, etc etc)
      and as Dale stated, which crank reluctor wheel you will have? (early LS2's were 24x, later ones and LS3 are 58x) pcm has to match/ compatible with it
      the later model 58x pcm/ crank, I hear from good tuners , are more desirable
      But as in everything, it comes down to your usage and budget when it pertains to which parts you "need" / can afford, rather than "want" and are "overkill" for your intended use ??
      the LS2's are going to be cheaper, since they are older/ smaller, but keep in mind that there are many different configurations of a 6.0L
      Are you set on a complete pullout or build fro scratch?
      some 6.0L's have the cathedral port heads, some have the "LS3" style rectangle port heads
      I have a buddy here in Vegas that is swapping a LSX 427 into his GTO and will be selling his cammed/ valvetrain upgraded L76 6.0L ("LS3" top end) engine for sale
      California
      The 58 tooth reluctor will offer better, more accurate cam position referencing. Its supposedly easier for tuning and over all a better design.
      The LS3/L92 heads are far better and more efficient than the cathedral port heads, they flow better on the intake and exhaust.
      The internals are better, the rods are a better composition and the pistons are normally coated and stronger.
      Birmingham, AL
      The L76 is a nice bang for the buck. Essentially an ls2 with ls3 heads and the pullouts are usually cheaper than an ls3. If I had it to do over again, I would probably go that route and skip the machine shop.
      Stephen
      Las Vegas, NV
      Quote Originally Posted by srh3trinity View Post
      Plus, the one that my buddy has, already has a cam and supporting valvetrain upgrades (springs and pushrods)
      great engine, just going way bigger and more $$$$ with a LSX Dart 427
      California
      Stephen is right, the L76 (08-09 pontiac G8) is essentially an Ls2 block with L92 heads. They are pricey though, a better alternative IMO is the LY6 is the same thing but an iron block.
      Birmingham, AL
      Quote Originally Posted by SShep71 View Post
      They are pricey compared to an LY6, but I have seen them sale for less than LS2's and I think it is because people just don't know which engine codes to search for. I will probably do an LY6 or L76 in a C10 after I get my Firebird finished. It is getting a 418 LS3.
      Stephen
