      ROBBIEVILLE
      Country Flag: Great Britain
      LS2 GTO Rail Cover on a Ls3
      Hi Guys I want to pull the trigger on the Ls2 GTO (grey ) fuel cover and put on my Ls3 66 gto project, can it be moded to fit ?
      Is it just clips that have to changed over ?
      Any help would be grateful
      Rob
      1966 GTO HELL BEAST PROJECT
      Sep 2008
      Farmington Hills, MI
      Yes, the LS3 has a noise shell over the runners, you may have to mod there or remove that noise cover, but the fuel rails are in the same location as an LS2, just add the ball studs on the valve covers (or coil packs, I forget).
      IIRC, the intake manifold noise cover sits 15mm higher than the surface of the runners, and you can remove it.
      HTH
      Michael
      79 Caprice - Iron LS2, [email protected]
      Engine builds in the works..
      ROBBIEVILLE
      Hey thanks for the response HTH - can I please ask if you have any link to the detail required for the conversion anything would be great ...
      Robbie
