    Results 1 to 13 of 13
      Sep 2011
      Lakeville, MN
      53-56 f100 rolling chassis
      Frame rails are original and fully boxed from front to back. Crossmembers are all custom with art morrison type center. Dual wilwood masters under floor on their 60 degree mount. 9 inch ford with back brace and a 4 link w/ panhard. I had started to convert it to a 3 link and only needs upper link bracket on housing. Mustang 2 lower crossmember with willwood 2 inch drop pro spindles. Upper control arms are spc and lowers are full tilt street rods. The upper control arms are mounted with howe racing circle track style mounts. The front and rear brakes are willwood 12.19 inch dynalites with the internal parking brake. All SS brake lines with AN flares. It has QA1 single adjustable shocks. Ride tech air pod and bags on all corners. It is set up for a LS engine with a 4l80e or a th400. Powder coated red candy vein. Fuel tank is from no limit. Anything in the pictures is negotiable including wheels and tires.
      $11,500 OBO
      pm if interested
      I can get more pictures if needed
      Thanks Brandon
      Sep 2011
      Lakeville, MN
      Sep 2011
      Lakeville, MN
      Also the chassis has been completely smoothed with all the holes welded up. All welds ground smooth, pictures are as i was building it. There are pieces of tubing in the frame to run all the wiring through. They start under the cab and go from there to the rear of the truck and the front of the truck. It also has front and rear Speedway Engineering splined sway bars.
      Sep 2011
      Lakeville, MN
      Sep 2011
      Lakeville, MN
      Apr 2008
      Ohio
      Looks like a nice build! Why are you letting go of her?
      Sep 2011
      Lakeville, MN
      I will be building a new chassis from scratch with autocross and road racing being first on my priority list.
      Sep 2011
      Lakeville, MN
      Sep 2011
      Lakeville, MN
      Mar 2014
      Lone Star State
      Very nice build!! If I had the spare change I would give you an offer but my current build is taking all my money. Always loved that body style.
      Sep 2011
      Southern Ontario
      It is non rolling chassis only? No body, powertrain etc?
      Sep 2011
      Lakeville, MN
      It is a rolling chassis minus wheels and tires. No body or drive train.
      Sep 2007
      Can you send me some more pics of the chassis. Where is the air pod mounted any modification needed to fit the body or will the factory cab and bed bolt right up. Please send pics and any other info to [email protected]
