    Results 1 to 15 of 15
      California City Ca.
      power steering cooler
      where should i plumb in my ps cooler, should i put it on the low pressure side of the sterring box? tia
      Dale Hayes
      87 turbo t
      May 2010
      kitchener,Ontario,Canada
      Yes low pressure side...and I would think that a power steering cooler might be overkill if the car is just a driver . I could very well be wrong though too.
      Ryan Austin
      Oct 2011
      Philipsburg, Pa
      Quote Originally Posted by instro84 View Post
      The PS cooler goes in the low pressure side. We use them on all our PT cars even if they're a street car. When sawing at the wheel at the occasional auto-x, a cooler really helps.
      rw
      Technical Support
      UMI Performance, Inc.
      [email protected]
      814.343.6315
      Join us on Facebook!
      Central CA USA
      If you have a fast ratio steering box, you need a cooler. The factory cooled them with a loop of steel line running over & back, just above the sway bar.
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by David Pozzi View Post
      yup, i know 3rd gens did. I modified one to use in my 77. I also used a magnafine filter that i suspect might have some cooling effect as well. I think i got the filter idea from mr pozzi but my memory is sketchy lol
      Scott from NJ.
      Vent Windows Forever! ...
      May 2010
      Well thanks fellas....I stand corrected I guess you do need a cooler lol
      Ryan Austin
      Hildebran, NC
      A goodguys small peanut (30ish second runs) will boil ps fluid........
      Central CA USA
      Quote Originally Posted by BonzoHansen View Post
      I ran the Magnafine filter on Mary's car. It won't work well with braided hose though, the braid won't expand enough to insert the filter nipple. Lee sells a nice inline filter with -6 hose ends. EVERY PS system needs a filter, ESPECIALLY a Rack & Pinion!
      Chicago suburbs
      Wow, I have never even thought about needing a power steering filter. I wonder if a magnet in the reservoir would be effective enough?
      Lawrenceburg, TN
      I run a power steering cooler with its own 8 inch cooling fan and a magnafine power steering filter, I use a AGR 12.1 steering box and a re-valved corvette power steering pump
      Central CA USA
      The GM steering boxes get by without them from the factory but way back when there used to be an internal filter inside the pump on some round necked GM pumps. On rack and pinion systems I've seen the rack boost fail due to a sticking flow control valve, probably due to metal shavings in the fluid. Adding a filter seems to have fixed it.
      David
      Chicago suburbs
      Can I just use normal "push lock" hose on the return side? I know it will handle the pressure, but will it be compatible with the fluid? The recommended hose is PTFE, but I was going to add a small filter with barbed ends and I am trying to keep things simple.
      Beach Park IL
      Yes, push lok is fine for the return side.
      Donny
      Chicago suburbs
      Ok thanks - push lok it is. Do you know what temp is too hot for power steering fluid? I'm guessing as long as it is above freezing it can't be too cold (?)
      Jun 2006
      Katy,TX
      A note on if you need a cooler. Years ago when I regularly autocrossed the 79 Camaro C/P 10" slicks IROC steering box I bought a Dorman "Help" line PS cap melted after a few runs. A GM one did fine but these things do make some heat.
      1965 GTO project car
      2004 Pulse Red GTO
