    Results 1 to 10 of 10
    Thread: Window Tint
      Colorado
      Window Tint
      I'm looking for a good (easy)way to remove window tint. Anyone have some good tips? The tint I want to remove is some cheezy, silver, 15 year old crap.
      Thanks in advance,
      Brett
      Connecticut
      good old
      razor blade, find a corner to start in and work from there.
      Jul 2002
      Mesquite, TX
      Seems like humidity/steam/moisture does it - let a car with tinted windows get a bit moist on the inside, leave it closed up while the moisture evaporates and re-condenses.. the tint will come off whether you want it to or not.
      Might take a little longer than you're wanting to wait, unless you've got one of those portable steamers.
      St.Anne Il
      ive taken lots off ..razor blade and plenty of water in spray bottle..keep it wet..it helps alot..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      westchester county new york
      go to the hardware store and get a 3 inch razor bade with a long handle, its usually in the paint department.The handle lets you use two hands , its way safer and easier.Use a lot of windex or soapy water to keep everything slippery. take off long strips an inch or two wide, if the blade stalls your taking off too much at once. I have removed window film from 20 foot tall windows so I have done my homework on this one.
      Stay away from the razor blade in the hand method unless you like the emergency room.
      NY
      I've used a razor blade and an alcohol based window cleaner. I think it was "clear vue" or something like that. The alcohol helps break down the adhesive quicker.
      The needs of the many outweigh the needs of the few.
      Apr 2003
      phoenix az
      moisture
      wet the windows down. wrap the inside of the window air tight with plastic and let bake in the sun. for an hour. remove tint
      Newbury Park, CA
      cuda's right. A black plastic trash bag works great.
      Colorado
      Black plastic bag trick. That was what I was looking for. I had heard something about that years ago, but couldn't remember the details.
      Thanks for all the replies.
      Brett
      Northern Indiana
      I was told by a window tinter...ammonia is what he uses. Just call one and ask what they recommend.
