    Results 1 to 20 of 30
      May 2011
      Northwest, MO
      Excellent. Thanks for those answers & the video.
      No problem. I really appreciate your help!
      I'll input all the data & be back on here in a few days. Would you measure the height from the ground to the CL of the rod end on each side of your panhard bar & post for me?
      When my dad and I mapped out the front suspension I figured those measurements would be important so they were actually included in the PDF I posted under the row with "Panhard Ride Height" obtained by measuring to the center of the rod ends.
      The axle end (on the driver's side) is 9 5/8" and the frame end (on the passenger side) is 6 5/8"
      The frame side is adjustable upward in 1" increments, with the 6 5/8" height the lowest setting, but modifications could be made to either end if necessary.
      Tyler Gibson
      There's nothing like building up an old automobile from scratch and wiping out one of these Detroit machines... That'll give you a set of emotions that will stay with you... Know what I mean? Those satisfactions are permanent...
