Thread: 69 Camaro Front Backspacing
09-12-2005 #1
New to Pro-Touring
- Jun 2005
- Fairfield, CA
- 31
Okay, I'm down, but not out! Any help is appreciated.
In the front I bought 18x8 Bonspeed wheels for my 69 Camaro with a 5" backspacing. They should have worked, but I have dropped spindles and a rear steer bolt-on Steeroids rack and pinion. The inside outer lip of the rim rubbed against the spherical tie rods. I put on 7/16" spacers, but they gave me less than an 1/8 of an inch space between the tie rod and the rim.
I have talked to MC Motorsports who is going to make me some hub centric adapters. My question is do I have them make me a 3/4", 7/8", or 1" spacer. The car sits pretty low and I am concerned about the tires rubbing the outer fender wells on turns. Unfortunately, I have 245/40-18 tires, I'm thinking I will have to buy 235/35 or 225/35.
When I pulled off the old rim/tire (15x7) the tire had rubbed pretty bad on the spherical tie rod and there was about 3/4" to 1" of space between them. Amazing how taking hard turns can do this. This concerns me because I don't want to get too close with the new rim/tire combo. I know there will be less sway with less tire now but still.
09-12-2005 #2
- Nov 2004
- NW Arkansas
- 1,742
What company made your drop spindle
Superior which is who we usually deal with says 4.5bs on the front for an 8in wheel! I would think 9/16 to 3/4 would be more tan enough room unless I am missing something!KENNY DAVIS HOTRODS
09-12-2005 #3
New to Pro-Touring
- Jun 2005
- Fairfield, CA
- 31
Thanks for the reply Travis
I am using either MP Brakes dropped spindles or Global West's. I will check the receipts tonight. I am thinking about going with 3/4". Here is a teaser pic.
