    Results 1 to 20 of 20
    Thread: minitub help
      Jul 2009
      central cali
      minitub help
      Hi, does anyone have a good thread that explains how to install the mini tubes , i dont have the dvd from "dse" thanks
      Apr 2012
      Woodstock, IL
      SchwartzPerformance
      Jul 2009
      central cali
      minitub help
      Hi there , my questionis simple i remove the inner tub and im ready to cut the floor and trunk pan , now do i make a line 3 inches inn, and then come back 3/4 inch out , that leaves 2 1/4 inwards right , now on the floor pan area do i have to. Cutit? Orbend itin a 90 degree so itwill bethe place to weld the spot welds to ???? And also do i weld them allaround the inaide of it ? Meaning to the trunk pan and floorpan ?? Dse instructions are very vage same as the dvd , thanks
      Jul 2009
      central cali
      minitub help
      My question is the fallowing , when installing a mini tub do i have to cut the floor pan or vend it in a 90 degree angle to spot weld the tub to it? Also after installing it , do i weld all-around the inside of the tub ? Thanks
      Apr 2012
      Woodstock, IL
      minitube help
      Bending it to a flange and spot welding is one way to do it- which can be easier than butt welding it depending on how good the tub would fit. We've also bent pieces of sheet metal afterwards to bridge that 90* angle.
      You don't need to weld the whole tub but you can. We spot weld it several times and seam seal when complete.
      -Dale
      SchwartzPerformance
      Cincinnati, OH
      You have to scribe the lines for cutting the floor pans b4 you remove the old tub. It works with a flange and without, but you can only bend the flange in the strait areas. Then you have a place for water to be trapped if you don't seal it well. Butt welds work great if you cut it nice. I welded solid then seam sealed. I have more pictures if you need them.
      Jim S.
      67 RS
      "driver "
      Aug 2006
      Nashville TN
      I never bend the flange but I always fully weld the entire tub along the floor. Accurate cutting and fitment is the key.
      Brian Finch
      Pro-touring Hero
      The Proof is on the Pavement
      Sponsored by Baer Brakes, JRI Shocks, Pennzoil, Tremec, Magnaflow, Centerforce, AFCO Racing, Kurt Urban Performance, Amercian Powertrain, Forgeline, Holley, and of course BFG.
      For the best engine money can buy please visit http://www.kurturbanperformance.com/
      Authorized dealer for Baer, Ridetech, Detroit Speed, Vintage Air, Motorstate Distributing, Wilwood Engineering, American Autowire, Forgeline, Holley, Afco,
      Contact brian@finchperformance for special Pro-Touring.com member pricing
      www.hotrodtransformations.com
      Mountain View, CA
      This is, IMO the best tutorial on the process contained on PT.com: https://www.pro-touring.com/threads/...a-68-69-Camaro
      True T.
      My blog
      Jul 2009
      central cali
      mini tub question for 67
      Thanks i will do
      Mountain View, CA
      Please don't post the same question in multiple forums.
      I've combined the threads.
      True T.
      My blog
      Cincinnati, OH
      IMO the DSE templates are all but useless on the 67. I made my own.
      Jim S.
      67 RS
      "driver "
      Nov 2007
      Bay Area, CA
      Having done a few searches on this topic, I found the above guide to be the best one and I plan on using it when I tackle mine. The number of pictures is a big help for the more visual among us
      Jeremy
      1967 Camaro RS- Always a work in Progress
      Jul 2009
      central cali
      minitub help
      Thanks again guys
      Jul 2009
      central cali
      This is what i got
      Jul 2009
      central cali
      minitub help
      I couldn't upload a picture i will do it later
      Jul 2009
      central cali
      67 camaro minitube help
      Thanks , do you know if there is a diference in minitub between the 67 and 69 ?? Y have a open space in my rear right side i patch it and that did the trick but makes me wonder if i order without specifying
      Feb 2012
      compton IL
      I made my own. imo it is easier than modifying stock ones. sometimes starting with a blank canvas is the way to go
      1965 mustang fastback. a pro-touring concoction of oem, race & custom fab...build thread here https://www.pro-touring.com/threads/...Racesteed-quot
      1975 harley ironhead custom long chopper. home built dream machine. fast, loud & beautiful
      Oct 2013
      By far the best tutorial. I had never done this kind of work before and nine turned out perfect using this. Good luck.
      Quote Originally Posted by Damn True View Post
      May 2002
      Northern California
      Quote Originally Posted by pollusky View Post
      you have to add a filler...i just extended the frame reinforcement up to fill.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2009
      central cali
      minitub help
      Thanks i did a small plate welded it and grind it off it looks good i still need to weld the tub nextweek when i go home maybe
