    Results 1 to 9 of 9
      North Carolina
      Brake hose on C5 conversion
      So I just did a C5 conversion on my 69. Is there any factory GM brake hoses that will work? I know the vette caliper is metric but what size is the hard line coming from the master.
      Any suggestions?
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
      Oregon
      Hard line should be 3/8-24 inverted flare, caliper is 10mm banjo...I'm sure there are OE hoses that could be made to work, but is there a reason you would prefer to rubber over reinforced braided stainless?
      It's what I does.
      North Carolina
      No reason, just looking to tidy it up and get a "baseline"....
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
      Dec 2008
      Detroit
      Quote Originally Posted by 69importkilla View Post
      Any suggestions?
      Factory hose will not work because the hardline is standard on the car end. Kore3 sells hose kits that are correct for this swap, metric to standard.
      http://www.kore3.com/products.php?cat=21
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Walla Walla, WA
      Silly me. On my '68 Camaro I used a braided stainless steel (Earls maybe) front brake hose set for a '68 Camaro and the 10mm banjo bolt for the caliper. Never had any issues with it. The rectangular banjo fitting on the brake line fit perfectly on the C5 caliper.
      Dec 2009
      I used the OEM C5 hoses with a small brass adapter from Napa to go from the late model bubble flair rubber hose, to the oringial Inverted flair hard lines
      the napa number was WH1442
      oreillys number is 271300
      worked perfectly, and if anything fails, I can buy parts at any local parts store.
      Aug 2005
      SF, Bay Area
      Do you happen to have a photo of how you routed the factory soft lines on your car?
      1965 Chevelle. PM me about wheel tool rental
      Jun 2010
      Deployed
      Why do you want an OEM hose?
      Place like Crown can make you what ever you want in what ever configuration
      1970 Camaro/DSE build
      Feb 2013
      South Carolina
      You can also call this guy: https://www.kore3.com/
