      Hackettstown, NJ
      WTB 42#/hr injectors
      Looking for a set of 8 Bosch / EV1 type injectors. 42#/hr injectors @ 58 psi (4 bar) (32-3 lb/hr @ 45 psi (3 bar))
      reply or PM
      Hackettstown, NJ
      Found a member with a set that is just bellow when I need. Could use for initial firing though. Any one with injectors as stated above?
      Dec 2012
      Edinburg Tx
      I have a set of fast 36# ev1 this are rated at 43.5 psi , so at 58psi it should be like a 42#
      Hackettstown, NJ
      At what duty cycle? Typically the 100% duty cycle 3bar flow rating is roughly the 80% duty cycle flow rating at 4 bar.
      What are you looking to get for them?
      Hackettstown, NJ
