    Results 1 to 8 of 8
      Sep 2013
      finding headers for a 66 Galaxie convertible should'nt be this hard,or should it?...
      I am having a hard time finding long tube headers for my 390 Z Code Galaxie XL.
      I keep seeing footnotes that say "not for convertibles".
      Anyone know what is up with that?
      Any recommendations would be greatly appreciated? I would prefer coated headers.
      Thanks,
      _Lance
      Sep 2013
      OK. Found out that the Convertible has a different frame then the other full size fords.
      Anybody got any suggestions?
      Oct 2006
      Saskatchewan, Canada
      Only suggestion would be to get a set for the hardtop and see how they fit or if they could be modified to fit. I would get the uncoated ones if you may be cutting them up and then get them coated when all the work to them is done. If I recall correctly the frame differences would be from approximately the firewall back so the interference would probably be somewhere around the header collector area so may not be real difficult.
      David.
      Sep 2013
      I will give it a shot. Got nothing to loose at this point.
      Thanks.
      Feb 2011
      Indpls, IN
      Check with Crites Restorations in Ohio. They may have a set that would fit.
      740-983-2273 or 4777
      Jan 2012
      I have ceramic coated shorties for my 65 convertible. I think Sanderson(I'll have to check if your interested) I'm very happy with them. for me it wasn't worth having the collector hang down which was what I saw with all of the long tube headers out there (crites I think)
      Nov 2013
      near Charlotte, NC
      Do the Ford cast iron headers that came with Interceptor motors fit convertibles? They appear to be great, if not heavy, headers.
      Conrad
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      Sep 2011
      Lakeville, MN
