Results 1 to 10 of 10
Thread: What spark plug to use
09-08-2005 #1
- Dec 2004
- Caledonia Ontario Canada
- 50
I am ready to drop in my engine. It is a 383 small block, Procomp aluminum heads, 202 160, Xe274 cam and 9.7-1 comp ratio. The cam is a flat tappet hedraulic. Any ideas what plug I should use? No NOS or boost. Just driver
09-08-2005 #2
Starting The Transformation
- Dec 2004
- Greeley, Colorado
- 485
I Love NGK plugs. I used them exclusively in my 2002 Mustang GT and my 2003 Cobra.
I'd recomend the TR6's. Generally you want to go as cold as you can without fouling the plugs. The TR6 should be a good choice for you. I really like autolite plugs as well.Jason Mounce
1969 Firebird | 2008 Corvette Z06 | 2008 Mustang GT/CS
09-08-2005 #3
- Nov 2004
- NW Arkansas
- 1,742
AC Delco
Originally Posted by JLM
I ran autolite race plugs in my SBC for a long time due to clearance issues.....IMO i would run delco plugs if I couldKENNY DAVIS HOTRODS
09-09-2005 #4NGK U-groove plugs are the ones I like, too. I would like to try the iridium Denso's though.....
[email protected]
09-09-2005 #5
- Dec 2004
- Greeley, Colorado
- 485
Originally Posted by gmachinz
I don't have any first hand experiance because I never used them. But the guys in the 03/04 Cobra world run far away from those plugs. Lots of stories of cracked porceline chipping off and falling into the combustions chambers. The general consensus there is that for the price of the plugs they are worthless.
But like I said I've never run them before so I have nothing to go by but hearsay.Jason Mounce
09-09-2005 #6Might be some confusion occuring here :
Ngk TR6 plugs are 3/4" reach taper seat plugs.
Most aftermarket Aluminum heads use 3/4" reach gasket type plugs
U-groove is the "name" that Accel uses
V-power is NGK's "name" of the performance oriented plug
Scottyz - If your heads require a gasketed plug, I'd go with the NGK FR5.
Those should work great w/ that comp. and last a long time. Good luck!
09-09-2005 #7NGK's routinely go half a season in 650-700hp 360" sprint car motors at 8500rpm, much of the time with a bad tune, around here. It's all I've ever used.
-Matt
09-09-2005 #8
- Aug 2004
- 223
your head manufacturer can probably provide some recomendations...
fwiw I run Autolite AR133's with my Dart angle plug heads.
09-09-2005 #9i'd use a autolite 104
09-10-2005 #10
