    Results 1 to 20 of 34
      Aug 2012
      Project Wayfarer
      Hey guys, so this is a new project to us. Lets start with the car
      1952 Dodge Wayfarer
      Texas Car
      Bought last summer
      The project has just started so we will update as the build comes along! The plan for the interior is bucket seats, carpet, navigation, radio, heat, a/c, etc. so the car will still be good for cross country road trips, or cross country road trips to the track :D
      Car has been fully stripped and every panel including the frame and body has been sent out for blasting. The car is back and up on a frame table, and the work begins....
      Engine/Trans:
      Dodge Gen 3 7.0L Hemi 426 stroker
      Stock Harness and Computer
      4l80e with paddle shifters
      Still on the fence about a supercharger or staying all motor, so any opinions would be appreciated
      Wheels/Tires/Brakes:
      Forgeline Premier ZX3P titanium finish
      BF Goodrich G-Force Rivals
      18x11.5---315's (rears)
      18x10.5---295's (fronts)
      Wilwood 6 Piston front calipers with 2 piece rotors
      Wilwood 4 Piston inboard mounted rear calipers with 1 piece rotors
      Front and Rear Suspension:
      Heidts Pro-G IRS from a 62-67 Nova
      Heidts Pro-G IFS from a 64-70 mustang
Size:  186.1 KBName:  DSC01492.jpg
Size:  210.8 KBName:  DSC01540.jpg
Size:  171.9 KBName:  DSC01539.jpg
Size:  182.3 KBName:  DSC01538.jpg
Size:  152.9 KBName:  DSC01488.jpg
Size:  159.8 KBName:  DSC01525.jpg
Size:  207.7 KBName:  DSC01526.jpg
Size:  188.5 KBName:  DSC01487.jpg
Size:  195.8 KBName:  DSC01527.jpg
Size:  210.4 KBName:  DSC01529.jpg
Size:  210.9 KBName:  DSC01535.jpg
Size:  212.2 KBName:  DSC01534.jpg
Size:  174.3 KBName:  DSC01532.jpg
Size:  181.7 KBName:  DSC01533.jpg
Size:  155.5 KBName:  DSC01536.jpg
Size:  163.4 KBName:  DSC01537.jpg
      Birmingham, AL
      Cool build.
      Stephen
      Aug 2011
      North Platte,NE
      Nice project! Is that an aluminum 426 crate? I would leave it NA if it is. Boosting a 426 doesnt really have any advantage over a 3.79 stroke 400" engine other than it sounds faster saying 4-2-6 lol! The shorter stroke engines seem to live ALOT longer in the 1000+hp range under boost without the extra cylinder thrust.
      Aug 2012
      Update
      Small update for you guys, started assembling the front end, rotors, bearings, caliper, rack, and sway bar. Wheel will be here next week and we will have some better pictures with wheels and clearances. Enjoy!
Size:  137.2 KBName:  DSC01551.jpg
Size:  177.8 KBName:  DSC01557.jpg
Size:  143.3 KBName:  DSC01560.jpg
Size:  190.8 KBName:  DSC01561.jpg
Size:  155.6 KBName:  DSC01562.jpg
Size:  201.7 KBName:  DSC01565.jpg
Size:  165.3 KBName:  DSC01566.jpg
Size:  174.7 KBName:  DSC01567.jpg
      Dec 2012
      I would love to see a top/plan view pic of the front upper A arms, they look from the partial pic as rather nice and robust.
      Nice build.
      Aug 2012
      will get requested pictures for you tomorrow!
      Quote Originally Posted by j-c-c View Post
      Nice build.
      Aug 2012
      little more progress, short day today as we found out we need a new oil pan with the sump mounted in the rear to clearance the crossmember and rack.
      Also, colors for frame and suspension will be decided tomorrow!Name:  DSC01574.jpg
Size:  158.2 KBName:  DSC01575.jpg
Size:  197.4 KBName:  DSC01580.jpg
Size:  197.7 KBName:  DSC01581.jpg
Size:  205.0 KBName:  DSC01584.jpg
Size:  162.9 KBName:  DSC01585.jpg
      May 2013
      SE Michigan
      I like this already!
      Aug 2012
      bump to the top!
      Dec 2012
      So looking closer at the IRS, I see a lower radius rod attached to the LCA, which begs the question, how is the radius arm arc absorbed by the LCA, and second question, what similarily restrains the upper control arm? It looks nice in place, just trying to figure it out.
      Aug 2012
      Not quite understanding your second question. To answer the first question, if you look closely at the pictures you'll see the pivot points for the radius arms have bushings and heim joints to allow for movement. Hope this answers your question!
      Dec 2012
      Ok, so the lower radius rod offers compliance by a flexible bushing on one end, which was hard for me to see, but makes perfect sense. The other question was mainly, if the lower control arm needs a radius rod, why doesn't the upper control arm need one also? Doesn't seem like the lower one offers any restraint to the upper arm, Don't sweat the answer, I'm just trying to figure out the design thru your pics, and this is to say again is a cool project.
      Aug 2012
      bump...wheels will be here this week!!
      Dec 2012
      I saw a Heidt IRS display at PRI, and i asked the non engineer rep about the reasoning behind the radius rods, I give him credit, he said without any BS he didn't know their purpose exactly.
      drool.
      Aug 2012
      The wheels have arrived!! here they are mocked up.. ride height in the front will be lower once the weight is over the front wheels. Next step is to pull it off the table and and mock up the engine and trans to make mounts for both of them!
Size:  152.2 KBName:  DSC_0850.jpg
Size:  146.1 KBName:  DSC_0851.jpg
Size:  131.4 KBName:  DSC_0852.jpg
Size:  139.7 KBName:  DSC_0853.jpg
Size:  155.9 KBName:  DSC_0854.jpg
      Jul 2013
      St. George, UT
      This thing has Badness written all over it. I think it's great to see the Pro Touring market opening up to cars outside the Muscle Car era. Kudos to you guys, and so far this is looking great. Where's your rendering tho'? ;) We wanna a sneak peak!
      Aug 2012
      Body is on the frame on the ground. Ride height is about set, we pull the fenders and rear quarters a bit to give us the clearance we need. The reverse oil pan is on the way for the motor so we can get the engine and trans set it.
Size:  201.3 KBName:  DSC_0857.jpg
Size:  172.6 KBName:  DSC_0858.jpg
Size:  104.5 KBName:  DSC_0859.jpg
Size:  129.8 KBName:  DSC_0860.jpg
Size:  152.7 KBName:  DSC_0861.jpg
Size:  156.4 KBName:  DSC_0862.jpg
Size:  141.3 KBName:  DSC_0863.jpg
Size:  138.0 KBName:  DSC_0864.jpg
      Aug 2012
      A little teaser of one of our personal cars.. 87 GTA, 385 stroker, d1sc, qa1 coilovers, tubular subframes......and much much more.. This was the owners first car at 16, sold and bought back 3 times and now is here to stay for good.. Was featured with an interview at last years optima Challenge at Road America.Name:  DSC_0867.jpg
Size:  193.6 KBName:  DSC_0866.jpg
Size:  166.7 KBName:  DSC_0865.jpg
Size:  157.1 KBName:  DSC_0868.jpg
      Dec 2012
      The car has an awesome, tough with slight attitude stance, Very Nice.
      And please don't use the HD straps for rigging again.
