    Results 1 to 10 of 10
      Milwaukee, Wi.
      Finally made some passes!
      Made it to the track for the first time today with my blower setup. My first pass just seemed to blow the 26x8.5 m/t tires off in first and second gear so I could not make a full pass, 12.32 @106. After a couple of those spooky passes I started leaving in second gear and I was able to go 11.94 @120. I never made a clean pass all day but I did manage a 11.492 @ 119mph using all 3 gears. The worst part was we were never able to data record from the lm1 (or o2 on the ecu). We later found out the alternator decided to quit and are hoping the lm1 just could not work properly with just a draining battery.
      Just thought I would share, Steve
      Kiler wisconson
      what gears you running?
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
      Jun 2002
      Long Island, NY
      Nice times, but more details on the car, please.
      Jul 2002
      Muskegon, MI
      I agree. Do you have any pics or information about your car? Sounds like it has the potential to be a low 11 second car high 10's.
      Milwaukee, Wi.
      Hopefully my computer does not lock up this time!
      Here is the specs on my 69 Nova (duh)
      383 sbc, Eagle forged crank and rods, Srp dished pistons and factory 1pc seal bock.
      Comp Cams hydraulic roller 224/236 @.050 .573/.593 116* lsa
      Trick flow 23* heads
      TPIS Miniram intake, 55lb inj., Electromotive Tec 2
      Rick's Stealth gas tank with Aeromotive a1000 pump
      TH400 man. shift, Precision Ind. 3200 stall
      3.5" driveshaft w/ 1350 joints
      Currie 9" ford w/ Strange center and Detroit locker
      Procharger d1sc 10lb boost and no intercooler-yet!
      Hotchkis front springs and sway bar, replacement multileafs in rear and KYB shocks all around
      26x8.5x15 M/T drags
      That should cover it. Thanks for reading, Steve
      St. Augustine, FL
      That sound like a pretty sweet car do you have any pictures. Oh and nice name.
      Andrew Petty
      Andrew Petty
      Kiler wisconson
      Nice setup..
      Should easily run low 10s if you get her to hook up.. Ya need some wider tires.. LOL
      Im taking my car to the track in two weeks.. Id be very happy with times like yours now..
      Brian
      Project JUST-N-SANE
      Milwaukee, Wi.
      Thanks for the compliments guys. I still have a whole bunch to figure out, One of them is to find out how big of a tire I can fit without a minitub.
      Brian, Where is Kiler WI and what track do you go to?
      Steve
      Feb 2002
      Springfield, MO
      Should be able to fit a 28x9 slick under it without much problem.
      Nice times. Unhook the front sway bar next time too! Should help BUNCHES!!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Kiler wisconson
      STEVE
      Kieler is in the very lowest Southwest corner of wisconson... I usually go to Tri state raeceway just outside of dubuque iowa..
      What gears you running?
      Project JUST-N-SANE
