      Sep 2012
      Help with rookie MII big brake kit.
      I have a TCI front with MII spindles on my 67 nova. This came with the less than desirable small cast disc brakes. What are the cheapest options/up grades for this set up? I read all the time ppl using corvette or Cadillac brakes but am unsure of what I can use other than wilwoods.
      Sep 2012
      Anything? You guys are a wealth of knowledge and I'm sure can lead me from making mistakes that cost money.
      NW Oregon
      Wilwood, Baer, Kore3 all make brakes for a MII spindle. I'd call Tobin at Kore3 to ask his input based on your car specs
      RobS
      71 Demon, 6.1hemi, paddled 4l65e, AlterK, Tri4,
      Yankton, SD
      13" Cobra brakes are a relatively inexpensive retrofit for the MII spindle but you'd have to get the hubs and rotors redrilled to 4-3/4" BC if you have GM pattern wheels.
      Sep 2012
      Wheels aren't an issue b I'm buying new ones so I can do any bolt pattern.
