    Results 1 to 19 of 19
      Mar 2013
      Pittsburgh, PA
      G Body Frame Modifications- looking for more info
      G Body Frame Modifications- looking for more pics & suggestions
      Nov 2013
      near Charlotte, NC
      Looking very interesting!
      Conrad
      May 2010
      kitchener,Ontario,Canada
      Search on here for project chili pepper....even has a pretty cool frame jig
      Good luck Ryan
      Nov 2013
      near Charlotte, NC
      RWolf
      Wish I still lived in Pittsburgh! South Hills. Nice work.
      Conrad
      Mar 2013
      Pittsburgh, PA
      Not my car, just looking for input !! Planning to copy the top 3 pics !! where do you live now???
      May 2010
      Well I do know with project Chilli Pepper they narrowed the frame in a similar manor and braced the rear cross member as well...the "middle" of the frame was also quite similar...id say definitely copy what you see in the photos..those old g body frames are just as crappy as they old a body frames.....very little torsional rigidity which is exactly what you need for a performance engine and "spirited" driving lol, I've seen some people box the lower front a arm mounts as well...box them in..
      Mar 2013
      Pittsburgh, PA
      Wow I like his frame Table!!! Way over the top !!! Professional Grade x 10 WOW. I wish I was closer, I would pay him to do my frame!!
      May 2010
      I'm not going to lie I love it too...I totally stole his ideas there ,I thought you could dig what he's done there and possibly get some info
      Good luck, keep the pictures coming
      Mar 2013
      Pittsburgh, PA
      so how are you going to level you frame, or did you already do the mods??? I need a few ideas before I make the leap!!
      I have a wood frame stand I was going to square up the frame on, the check for measurements then weld up supports!!
      May 2010
      Made some screw adjusters like they did.....just used long bolts as opposed to the expensive swivel pads they used then tack the frame to the bolt....make sure you have a jam nut on there to so once you set the height where you need you can lock it in place . To make something similar to them you'll need probably about 40 feet of beam..2 15 foot and 2 5 foot, then just throw some tubing across the beams where you want to place the height adjusters a Lil tacking and away you go
      Mar 2013
      Pittsburgh, PA
      I would pay some one to do the work before making the frame table!!
      Any pics??
      Nov 2013
      near Charlotte, NC
      I'm in North Carolina near Charlotte. Where are you in Pittsburgh?
      Conrad
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      Nov 2013
      near Charlotte, NC
      FWIW, guy is now making kit to box in the center section of the GM G-body frame. I ordered one and it arrived yesterday. It is weld-in. Will let everyone know how it looks when open the box.
      Conrad
      Mar 2013
      Pittsburgh, PA
      Boxing the center frame rails is the easy part 4 inch plate 1/8 thick and a cut out for the mid body mount!! I'm South of Pittsburgh 15317 about 20 Mins. near the Meadows Race Track
      On the Frame Jig, I would have to make mine a little longer for the Elco, that's a lot of work for one project. LOL
      Jul 2013
      St. George, UT
      Just remember with bracing, make sure that you keep in mind all the parts besides the frame you have to clear- floor pan, exhaust, fuel tank, trailing arms, etc. I ran into some slight issues bracing my frame and then putting the body back on the frame and the rest of the car back together. It was all relatively easy to overcome, but I had to change some plans as a result. Good luck!
      May 2010
      Mooresville, NC
      Quote Originally Posted by alphaenvirmgt View Post
      Conrad
      Born and raised in Bethel Park, PA and now in Mooresville, NC. Small world.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Mar 2013
      Pittsburgh, PA
      LOL, Hey Ben I have been measuring everything before I pull the shell off! I have plenty of pics for reference, some are yours! LOL I plan to run the cross member, right behind the rear floor pan, plenty of room to install a 2x4 with exhaust cut outs and Loop. I also have a new floor pan to use while I modify the frame!!
      Nov 2013
      near Charlotte, NC
      Marc,
      Very small world! Do you have a Regal? Ever come to Albemarle?
      Conrad
      [email protected]
      Mar 2013
      Pittsburgh, PA
      I lived in Upper St. Clair !!! LOL up to 4 years ago !!
