    Page 2 of 2 FirstFirst 1 2
    Results 21 to 38 of 38
    1. #21
      May 2002
      Northern California
      Quote Originally Posted by Mr Nick View Post
      Please do. If my current (3rd one) master cylinder goes out, then I'll probably try the one you posted. But I think I was able to get a good position with the Hurst unit after some minor fab work.
      I believe it had a lot to do with your angled extension. The master needs a straight rod to work right. You can even change the angle of the rod in relation to the master few degrees and it won't wear out like that.
      How is your pedal pressure now? What is your master bore size?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    2. #22
      Oct 2010
      Mena, AR
      Will be keeping an eye on this thread. I really like that last bracket and looking forward to the feedback and a link. As I am going to be fitting a t56 into a 67 elky, this could be beneficial.
      Thanks, Chris
      Chris
      1967 ElCamino
      2004 Chevy SSR (my sons)
      1951 Chevy pickup(my sons)
      1967 Elky https://www.pro-touring.com/showthre...587-Evil-Angel
      1951 truck https://www.pro-touring.com/threads/...3-year-old-son
    3. #23
      May 2002
      Northern California
      Quote Originally Posted by bmbrzmn101 View Post
      Thanks, Chris
      We will see how that bracket works. It was designed for a Camaro but happens to fit a chevelle booster flange. Lets see if we can get the ratios and piston sizes right. I'll be working with Wayard to see if we can get a system that works and a soft pedal.
      Im not a vendor here so i can't say much more on that.
      The main problem with the Abodies is the pedal and getting the right throw from it. Im working on that too.
    4. #24
      Jan 2014
      New England
      I bought the bracket and cylinder kit for a 67 f body,
      out of my full collection of brackets and cylinders that i purchased the one from Mean Streets was by far the best alignment... customer support is great to !!!
    5. #25
      Quote Originally Posted by Frank 67 View Post
      Can you post a link to this bracket please?
      Instagram @projectgattago
      Dr. EFI
    6. #26
      Jan 2014
      New England
      May 2013
      qld Australia
      Country Flag: Australia
      I had same problem, I found out that the master sylinder and the pushrod all has to be in line, even if it is on an angle it all has to push straight and with that fabricated angled pushrod you have it will be causing down pressure on the bore and be damaging it.
      Mopar or no Car
      Your either with us or Behind us
    8. #28
      Mar 2013
      Was anyone able to verify the proper alignment with clutch pedal and the Meanstreet bracket for A body use? It looks like the best option for brackets I have seen unless I am missing some from my searches.
    9. #29
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by oldsfromyell View Post
      We build an A-Body specific hydraulics kit if you're interested.https://www.bowlertransmissions.com/...let-reservoir/ That is an example of what we have. There are some options for plastic versus billet reservoir that will alter the price some. Let me know if you have any questions.
      visit us on the web at www.bowlertransmissions.com
    10. #30
      Mar 2013
      Thanks, I am interested in the firewall bracket with adapter and the pedal bracket. I will be in touch soon.
    11. #31
      Jonesboro, Arkansas
      Is it weird that I get excited about a properly functioning bracket? Must be something about bringing two items together to work well together.
      I wouldn't think anything weird about it at all! I like it when a plan comes together. Besides after something bugs you for a while it's good to see something finally working.
      Carl Wilson
    12. #32
      Jul 2011
      Nashville/ Tampa
      Has there been any progress made on this front? Did the mean street bracket work for anyone with an a body? My ebay bracket that looks like the Bowler one posted earlier completely sucks.
      Mean Street's website doesn't work so I'm not sure if they still make theirs or not, but these look like the options for now. Hard to find much info from people who have actually used one (esp w/ hydroboost).
      Silver sport makes this, which looks interesting but is pricey though it appears to come with everything https://shiftsst.com/store/hydraulic...ulics-kit.html
      American Powertrain makes these, which you can also buy on ebay (meaning you can probably save $20 pretty easily w/ coupon) http://americanpowertrain.com/c-3140...ystems-gm.html
      Then there is another Bowler that says it's for 67-72, which seems odd because some other places split the 67 and down from 68 and up. https://www.bowlertransmissions.com/...kit-gma-68-72/
      I had been thinking about making one of these myself, looks like a good way to pretty much ensure the angles stay right throughout pedal travel https://www.bowlertransmissions.com/...er-kit-billet/
      Of these the options the cheapest is just getting the bowler bracket and using a stock master, which might be the way to go since I don't want to pull my trans and do a whole new master/slave if I don't have to.
      Edit- It looks like you can duplicate the American Powertrain kit - but with a quick disconnect - for $370. With ebay bucks or a coupon you could knock that down to $330ish.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
    13. #33
      Apr 2016
      I got the bracket set up for my 67 from Bowler and it fit like it should...
    14. #34
      Jul 2011
      Nashville/ Tampa
      What pedal did you use?
    15. #35
      Apr 2016
      I used a stock 67 pedal set up, and I got the bracketry, master cylinder, bleeder kit, and hydraulic throw out bearing from Bowler... They were recommended to my by Jodie's Transmissions, who I bought the Legend LGT 700 from...
    16. #36
      Feb 2011
      dallas, tx
      after 10k miles mine started leaking from the boot. Looks like i need to pull it and replace it. While im at it i might get with a different bore for easier foot pressure. Im currently using stock ls7 clutch with my ls3 and t56. Any size recommendations?
    17. #37
      Jul 2011
      Nashville/ Tampa
      Just ordered the Bowler stuff. Craig - I'm guessing the one who posts here - answers emails quickly and answered the phone when I called with questions so that (and the forum discount) sold me. On the phone they were able to take out the the braided line since I already have one, and I opted for the longer-travel of the two bore options (car is mostly street by far and current setup is like an on/off switch). I also came across this video which made me not want to mess with the Hydramax stuff. It looks doable, but I'm past the point of wanting to mess with things to make them fit. https://www.youtube.com/watch?v=DKIOE5fl2jo
      I also have some stock pedals in the garage, so when I get home in a few days I'll post updates of how this works out. Considering even an off-brand stock-style is master can be close to $100 paying a few bucks more for something better seems like a no brainer.
    18. #38
      Jul 2011
      Nashville/ Tampa
      Well I got everything in and for whatever reason the master rod is nowhere near long enough to work with the stock pedal that is suggested. Even fully extended it's way short. To get it on you'd have to put the pedal against the firewall which obviously won't do. The pedals are used now so no way to return them, so that's money wasted. Fortunately I had that McLeod pedal, which seems to work ok with the mod to it I had made previously. No clue why the Bowler is said to work with the stock pedal; in my case there is zero chance it'll work, I wonder if it's because I got the longer-throw master? Hopefully will find out more when Bowler opens on Monday.
      Edit - this is the supposedly stock pedal I got from Summit, maybe it looks like a real stock one, maybe not, I dunno. Either way it doesn't work, so don't use it. What I ended up doing is drilling a new hole in the tab I welded onto my McLeod pedal 1/4" from the old one and now it works great.
      Left is the McLeod before I drilled the extra hole compared to the "stock", right is the repro. No way in hell the MC rod would reach that, at least not in my case. McLeod bracket is really nice, I'd use it again.
Size:  78.3 KBName:  42829794892_6469c3c958_z.jpg
