    Results 1 to 1 of 1
      94 camaro bulkhead connecter disassembley
      Hey guys,
      Im in the process of scraping my 94 Z28.
      Does anyone have a pointer on removing the bulkhead connector on the drivers side which connects the front to the main body harness under the dash?
      There is a sheet metal screw with a 7 mm head that holds it to the firewall in the engine compartment, along with two push retainers that must be squeezed from under the dash. I have these loose and free, but need to separate the two.
      On all of my older cars, there is a bolt that holds the two together.
      This is basically my last connection and then I can remove the entire harness from the car.
      Thanks for any help,
      Dan
      2,500th member!
