    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 41
      Sep 2011
      Pickerington, OH
      Need help: LS swap options
      Hello all,
      i have been building my 76 Monte Carlo as pro-touring themed and now it's time for engine/tranny purchase.
      I am looking for some suggestions for swap combos and price. Use for the car will be mostly street with occasional track day.
      Needs:
      LS
      at least 400hp+
      6 speed
      engine controller
      Hedders
      budget= 11000.00
      any ideas or suggestions will be greatly appreciated.
      Thanks, Scott
      savannah,ga
      used lq4 or lq9 from a salvage yard. Easily make 400 hp. Cast iron block makes it strong and these engines are cheap, several low mileage engines have got to be within spitting distance of you. GMPP crate engines will get it done, too. More money though. The t56 or tr6060 will eat int your budget quite a bit as well. Headers from Stainless works run 900.00 or so. PSI performance has a pretty good price on the harness which can be modified to fit your application. The parts for sale section on this forum will be a big help, that is where I found my t56. good luck.
      Sep 2011
      Pickerington, OH
      Quote Originally Posted by Tom Welch View Post
      Thanks for the reply Tom.
      Do you think a LQ4/LQ9 with stock heads/intake would do it, or switch to the LS3 stuff?
      Should I leave the stock bottom end as is if everything looks good?
      Do you think something like a FAST harness and controler would be worth the extra money? I am guessing this would save on tunning and dyno time.
      Thanks, just trying not to dig myself in a hole that is going to cost more in the long run as opposed to going with a pre-built short block or somthing.
      St Louis
      Go with an LQ9, 400hp with just exhaust and a tune (link below). Lots of LS T56s out there. Looking at under $2000 each for good, low mileage pieces (motor should include accessories, sensors, ecu, harness, petal, etc for that price).
      Leave the motor stock, use stock ecu, no dyno time needed. If you want you can swap intake, cam, heads to put you over 500hp. That was my plan, but found I was very happy with it in stock form. Bottom end will hold up to lots of hp.
      http://www.hotrod.com/techarticles/e...#ixzz21ehbAsre
      Birmingham, AL
      Don't forget to factor in your fuel system. That being said, you should be able to accomplish this with your budget. there are plenty of people that make good power with cathedral port heads. If you decide to do a cam swap there are plenty of, options to make good power. You may have to switch to a car intake for hood clearance.
      Stephen
      Sep 2011
      Pickerington, OH
      Thanks to all that are chiming in, I have been having a tuff time trying to decide which way to go. Now that I finally have money to pull the trigger I keep second guessing my choices as if there is something better out there.
      For the fuel system I have a quote from MCB for a ricks tank with the vaporworks setup.
      My other area of concern is engine mounts and tranny crossmember. A 76 monte carlo is probaly the least popular option for this swap (it is no first gen camaro) so info is scarce.
      Thanks, scott
      California
      Scotty I sent you a PM
      St Louis
      You can save a few bucks by using the stock GTO or Corvette exhaust, if they fit. They flow really well and can be found used for about $50.
      http://www.carcraft.com/techarticles...e_header_test/
      Sep 2011
      Pickerington, OH
      Quote Originally Posted by garys 68 View Post
      Thank you for the link, that's some good info. Although not much is as cool as a set of stainless hedders.
      St Louis
      Less money on "show" means more money for "go".
      Quote Originally Posted by scottymonte View Post
      Birmingham, AL
      There was a low mileage ls2 and t56 in the classifieds on lateral-g.net
      http://www.lateral-g.net/forums/showthread.php4?t=42416
      Stephen
      Sep 2011
      Pickerington, OH
      Quote Originally Posted by srh3trinity View Post
      Thanks for the link, I will try to contact him. Shipping from CA to OH has to be crazy though.
      Birmingham, AL
      If you go from dock to dock, freight isn't too bad. I bought a block and rotating assembly and from Tx to AL it was reasonable. Certainly a complete engine and trans is going to cost more, but if you can't find one locally and you buy that right it might be worth it.
      Stephen
      Nov 2011
      Livermore, CA
      Depending on the weight of the motor. Last time I crated my motor up and shipped it, it was a few hundred dollars. Although the weight of my engine was under 500 lbs and thus could use a standard handtruck. Nothing special.
      Tory
      Sep 2011
      Pickerington, OH
      Thanks for all the info guys, my over all plan is starting to come together.
      I plan on getting the ricks tank order in this week. Along with either the BRP swap kit or dirty dingo LS mounts(still not sure on the best way to go here). I am concerened about not finding a cross member that would fit if I do not use the BRP setup, any thoughts?
      Thanks again,
      Birmingham, AL
      The dirty dingo sliders would help. Check out crossmembers.com or I think american powertrain makes a universal
      Stephen
      St Louis
      On the crossmember, Speedway motors sells universal ones in various drop heights pretty cheap. Mock it up, see what you need.
      On shipping, I've bought 2 motors on ebay. Lowballed an offer by email after the auction closed without a sale at reserve. Shipping for a motor alone was under $100 to a truck freight terminal. One even hat it here the next day! Has to fit on a pallet, so not sure if trans and motor could ship together.
      Sep 2011
      Pickerington, OH
      Hello, thanks again for the input.
      I found a LS1 / T56 GTO take out with about 75k on it. What is a good price for one of these? Is there any big reason not to go LS1 except for the limited head options?
      Thanks,
      St Louis
      Price mainly. Aluminum blocks get about 3x the price of iron. Shifter position on the GTO is set back, might be an issue.
      Dec 2008
      Detroit
      If you're in OH, why don't you call Cleveland Pick-a-Part? They are always selling full swaps. They have and LS2\T56 on ebay now. I have never used them, but I think they used to advertised on Lateral-G a lot. You can also get those heads ported or swap in 243 heads.
      http://www.clevelandpickapart.com/
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
