    Results 1 to 20 of 28
      Near Dayton, OH
      Turbo headers: mild steel or stainless
      Just wondering if, as long as you have mild steel coated with Jet-Hot or similar product, will it hold up to the exhaust temps of a turbo setup as well as stainless?
      Thanks,
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      Dec 2002
      Lost Wages, Nevada
      Uhhh. You did just say squirrel headers, ..... Id say stainless 304 at a minimum, if not 321, or at least just for the flanges themselves.
      Or if you really up to it how about inconel ??
      You will dis-color Jet-Hot or Olympic or any other ceramic coating with the use of squirrels, just from the saturation temperature under moderate boost.
      Jun 2002
      Long Island, NY
      Quote Originally Posted by chicane67
      Uhhh. You did just say squirrel headers, ..... Id say stainless 304 at a minimum, if not 321, or at leastr for the flanges themselves.
      Oof. Isn't inconel like $373.48 a foot these days? I'll agree with Tom on this. If you're going with Turbos, don't skimp, go with 321 stainless.
      Yup. Mild steel will not make it. If in doubt, have a look at the video of the Mule's headers on a recent chassis dyno. They turned orange from the heat. I don't think anybody's header coatings can handle that.
      jp
      ​John Parsons
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by Ralph LoGrasso
      It aint cheap... At work we use several "muffles" (basically rectangular tubes) which are inconel that are 20'L X 8"W X 4"H and the wall thickness is about 3/8". The replacement cost is $10k each and we have 4 of them that get replaced about every two months or so.
      YEEEOUCH!!!
      IMO inconel is over kill for anything thats street legal 321 is your best bet if you have the extra dollars to spend but if youre pinching pennies then 304 is fine if the welds are quality work and some thought is done on tube placement to ease the expansion stress from the heat.
      I built a set of turbo V6 headers from 16 guage mild steel and had them coated with the high temp (2k deg) ceramic coating and they held up fine. Of course the longest the engine stays WOT is 1/4 mile so the mild steel doesnt really get hammered continuously with high heat which IMO is why they are still alive. Next set I do will be 304 as soon as that money tree thing takes off and I can pick up a TIG welder.
      My .02
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      San Antonio, Tx
      can you mig weld a set of turbo headres? or is that not recomended? i'm going to build mine with 321 also.
      Instagram: CamaroAJ
      Jun 2005
      You can make them out of mild steel using weld els. These are 90 degree smooth (mandrel type bends) that are 1/8 inch wall thick. You can use these with schedule 40 straight pipe (also 1/8 inch wall). All available at McMaster or your local industrial plumbing outlet.
      Pic of mine after I wrapped it:
      It actually weighed about the same as the stock cast iron manifold. Search Google for weld el manifold you'll find a few examples.
      Anthony
      http://www.cardomain.com/ride/674663
      It's not just the material, it's the design. If you use thick wall as mentioned above, mild steel works. Heck, with enough mass, cast iron works (see any OEM setup). But, if trying to reduce weight, then progressively higher quality materials will be required.
      Nov 2003
      Paradise, Ca
      Quote Originally Posted by CamaroAJ
      Use 347 filler and preferably tri-mix gas and don't look back. As with TIG, you will have to purge the inside of the tube.
      -Matt
      Camarillo, California
      You're doing a non intercooled setup on a 7M? Do you have it running yet?
      Jake
      Quote Originally Posted by Supra510
      Anthony
      Jun 2005
      I have it running. Just did a track day at PIR yesterday. It is intercooled (air to water). Here is a pic of the completed engine bay. You can see more pix at the site listed below.
      Anthony
      Very cool. PT a little differently. I have a 73 SS nova that is going full out but I also have a highly modified 88 turbo and a 85 Supra going turbo. Car looks bitchen.
      Jake
      Jun 2005
      Thanks, finally about finished with the mechanical side, or so I thought 'til the clutch started slipping at 17psi at the track day. Had to turn the boost down. I'm running the W58 trans and I think it's giving up the ghost as well so looks like an r154 and new clutch are in the works before next track day season. Good news is I can still drive it fine and run any kind of autocross without any issues the way it stands. It's always something.
      Anthony
      why'd you put the thermal wrap on the compressor outlet???
      Jun 2005
      To keep heat out of that pipe. You might be thinking that I'm keeping it in (since that's what it does for the exhaust), but it does a good job of keeping the heat from the engine bay out as well. There is a bare spot on the pipe right by the intercooler. Prior to doing wrapping the pipe it was so hot in that area that I could not touch it even after normal driving. Now I can easily touch it. Would probably work even better if I wrapped it in something reflective, but I haven't needed to at this point. It gets really hot in there at track days. I have all my exhaust wrapped including the turbo and I've still melted plastic wire covering (whatever that black stuff is called) that is 8-10 inches from anything.
      Anthony
      I STILL think you may be keeping it in. at 17 psi boost, you're looking at discharge temps of about 100C even with 100% efficiency (which you know you don't have), and at part throttle you don't really care if you're heating it or not. Just becuase you can now touch the pipe doesn't mean you've improved the situation. I'd reconsider, or at least take some measurements if i were you. I think you would find that you would be better off employing heat shields (if necessary, it doesn't look like the intake has a line-of-sight to the exhaust) and controlling underhood air than using thermal wrap, imo.
      They make two grades of corrugated loom, by the way. The high temp stuff usually has a gray stripe and is good to 150C, the other stuff melts at 90.
      Jun 2005
      You may well be right, a thermocouple would tell the tale. It probably doesn't matter that much one way or the other, it's not like boost is in the pipe very long. I just figured I'd rather have a cooler pipe to start with and this seems to do it.
      Anthony
      yeah, it's hard to say, but if you think about it, thermal wrap makes the exterior of your exhaust "feel" cooler while simultaneously keeping the exhaust gasses HOTTER by inhibiting heat transfer to the surroundings. This is what i was getting at by saying that just becuase the wrap allows you to touch the pipe doesn't mean it's actually doing anything beneficial. If i was at home i could guesstimate it (actually prob not, i have no idea about airflow rates across that tube underneath a hood). You're probably also correct that it's probably not a big deal either way, but if you're gonna do it, might as well do it right!
      I built a twin turbo setup on my big block vette last winter. I was going to use stainless but decided to do it out of mild steel first to see how it would work. I have been running it this summer with no problems so far. I want to redo it out of stainless some day and it will be easier since I have patterns now. If you want to experiment with your setup first I would suggest doing it with mild steel as its lots cheaper and easier, then when you get it how you like it, go with stainless.
      Mike
      Turbos, 1700.00
      Hot Side, 1500.00
      Cold Side, 1,000.00
      Fuel System, 1,000.00
      The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
      Nov 2004
      Tinley Park
      i have read that mild steel is fine as long as you have the turbo supported also with a simple bracket that takes the stress off the header.
      thats the way i am doing mine, mild steel thats been ceramic coated. i dont have the ability to back purge the material to weld stainless...
      pain is nothing compared to the emptiness that comes from quitting.
      owner of "Primal"
      1970 Camaro RS
      http://www.cardomain.com/ride/2092707
      Camaro Z28
