sbdavis1
06-20-2013, 10:39 AM
Hey guys,
I was working with a local shop here in Tempe AZ to get a set of wheels made for my 69 Camaro build. They fell off completely and now I'm moving it forward myself. I was given these measurements and wanted to get some advice to confirm.
5x4.75" PCD
70.8mm center bore
FRONT AXLE
19"x9" with 4.5" back space
48mm spindle protrusion
0 caliper protrusion
177mm caliper overall diameter
Rear AXLE
19"x10" with 6" back space
2mm hub protrusion
For Some reason, in the emails I was receiving from the shop, he kept referencing 19x8 in the front and 19x10 in the rear when we were going through pricing. In his measurements provided to a few wheel manufacturers shows 19x9'' in the front as listed above.
I am concerned with clearance etc and do NOT want to have to rebuild the wheels.
Camaro is on all speedtech suspension with the wildwood 4 piston setup. new upper and lower control arms, coil overs and torque arm kit. If it's a 9'' front width wheel I plan on running a 255x35(I believe)x19.
Thank you in advance!!! Wheels are mocked up and ready to start build but clearly need to confirm as we just noticed the discrepancy.
Thanks!
Spencer
5x4.75" PCD
70.8mm center bore
FRONT AXLE
Rear AXLE
2mm hub protrusion
Thanks!
Spencer
