View Full Version : 69 Camaro Wheel HELP
sbdavis1
06-20-2013, 10:39 AM
Hey guys,
I was working with a local shop here in Tempe AZ to get a set of wheels made for my 69 Camaro build. They fell off completely and now I'm moving it forward myself. I was given these measurements and wanted to get some advice to confirm.
5x4.75" PCD
70.8mm center bore
FRONT AXLE
19"x9" with 4.5" back space
48mm spindle protrusion
0 caliper protrusion
177mm caliper overall diameter
Rear AXLE
19"x10" with 6" back space
2mm hub protrusion
For Some reason, in the emails I was receiving from the shop, he kept referencing 19x8 in the front and 19x10 in the rear when we were going through pricing. In his measurements provided to a few wheel manufacturers shows 19x9'' in the front as listed above.
I am concerned with clearance etc and do NOT want to have to rebuild the wheels.
Camaro is on all speedtech suspension with the wildwood 4 piston setup. new upper and lower control arms, coil overs and torque arm kit. If it's a 9'' front width wheel I plan on running a 255x35(I believe)x19.
Thank you in advance!!! Wheels are mocked up and ready to start build but clearly need to confirm as we just noticed the discrepancy.
Thanks!
Spencer
sbdavis1
06-20-2013, 10:50 AM
https://static1.pt-content.com/images/noimg.gif[/URL][/IMG]
