    Results 1 to 12 of 12
      Eastern Virginia
      Compressor fittings for Sanden SD7 compressor?
      Where do you get them?
      Scot
      86 Monte SS
      Apr 2012
      Woodstock, IL
      Compressor fittings for Sanden SD& compressor?
      Vintage air, billet specialties, march performance all sell fitting manifolds
      SchwartzPerformance
      Aug 2012
      Peoria, AZ
      Lance
      Eastern Virginia
      Had to change thee subject, its for an SD7 compressor. The little one with the "peanut" style fittings. Called than
      That cause the flange is oval, looks like a peanut. I'd like them to bolt on, have a 90 degree bend with a bead lock crimp. Haven't seen those, may have to go with threaded instead of crimp.
      Scot
      86 Monte SS
      Did you find one??
      Sep 2010
      Santa Clara, CA
      Search for "p418" and see if that March manifold is what you are looking for....
      Steve
      Eastern Virginia
      Quote Originally Posted by sjaroslo View Post
      Yes same fitting however, the port on that compressor is in the 12:00 position, mine is at 9:00. So it won't work on mine.
      Scot
      86 Monte SS
      Eastern Virginia
      Quote Originally Posted by qnitro View Post
      Did you find one??
      Still trying to figure out what I am going to do, so haven't ordered anything yet.
      Probably go with these: http://www.ebay.com/itm/Peanut-Style...6e3806&vxp=mtr
      Would like to find them where the flange is one piece & both fittings are connected to it, all one piece instead of two.
      Scot
      86 Monte SS
      Sep 2010
      Santa Clara, CA
      OK, sorry about that.... Not to belabor it, but just wanted to make sure that you're certain of the orientation; I only bring it up because I assumed that my (uninstalled as of yet) unit had the fittings at 12:00 but then realized by looking at other people's pictures and looking at my brackets and the mounting tabs (I have the Wegner kit) that it would in fact be mounted at 9:00.... Good luck.
      Steve
      Apr 2012
      Woodstock, IL
      Is this not what you're looking for?
      http://summitracing.com/parts/mch-p417
      SchwartzPerformance
      Eastern Virginia
      Quote Originally Posted by Schwartz Performance View Post
      Yes I think that will work. $71! wow.
      Scot
      86 Monte SS
      Sep 2004
      Metamora, Illinois
      I got mine from Vintage air and they were a little cheaper. I believe they are on this page
      http://www.vintageair.com/2013catalo...ebpgs%2073.pdf
      For the fittings themself I went with the EZ Clip setup. Not the cheapest option, but the smaller hose diameter and increased flexibilty allowed me to route the hoses just about any way I wanted.
      http://www.vintageair.com/2013catalo...ebpgs%2074.pdf
