View Full Version : Bump steer kit MS II
no go nova
05-15-2013, 06:33 PM
Does anone make a bump steer kit for MS II spindles?
feeble
05-15-2013, 06:48 PM
Not inexpensive: http://www.summitracing.com/search/Brand/Baer-Disc-Brake-Systems/Department/Chassis-Suspension/Part-Type/Bump-Steer-Kits-and-Components/Make/FORD/Model/MUSTANG-II/
I also seem to remember being able to piece something together with parts from Speedway Motors.
no go nova
05-16-2013, 08:51 AM
boodlefoof
05-18-2013, 11:30 AM
You can get bump steer studs at Speedway, Coleman Racing, Lefthander Chassis and others and then you can run a rod end as the outer tie rod end. Just need to figure out what other bits you need to buy/fab to make that rod end fit on your tie rod.
Bryce
05-19-2013, 09:32 AM
this is what I did:
https://static1.pt-content.com/images/pt/2013/02/tn_full_02242013271jpg_Thumbnail1-1.jpg (http://www.motortopia.com/photos/712931)
https://static1.pt-content.com/images/pt/2013/02/tn_full_02242013270jpg_Thumbnail1-1.jpg (http://www.motortopia.com/photos/712930)
https://static1.pt-content.com/images/pt/2013/02/tn_full_02242013269jpg_Thumbnail1-1.jpg (http://www.motortopia.com/photos/712929)
I drilled and honed the spindles and centerlink to .495" a press fit for a 1/2" shoulder bolt and used rod ends.
