View Full Version : MOPAR part vendors
MidnightSpecial
05-14-2013, 10:13 AM
I need some help finding pro-touring parts for a 1968 Coronet. Seems like all the vendors out there specialize in either Chevy or Ford. If they do have MOPAR parts, it seems to be very limited. Not much love for the MOPAR owners. I wish I was skilled enough to fabricate most of this stuff myself...but that isn't gonna happen.
I plan on throwing the links in this post if I get some feedback. Some other members may have the same issue.
The only one I know of at the moment is XV Engineering.
I would really appreciate some feedback.
jeff s
05-14-2013, 11:04 AM
We have a "Bolt In" 1968-1970 Mopar B Body full chassis as well as 1970-1974 E Body, Cuda, Challenger full chassis. We will also build virtually any custom chassis. Email us for a detailed price sheet.
Jeff
69 Charger 440
05-14-2013, 12:54 PM
I use the Hotchkis TVS setup on my 69 Charger and love it. All of it is bolt on (except sub frame connectors) so no heavy fabrication or cutting to make it all fit. Works great with their new Fox/Hotchkis shocks and gives a huge improvement in the handling department. No complaints from me with Hotchkis parts.
http://www.hotchkis.net/
Another great company is Firm Feel inc. They have full suspension kits and offer a firmer steering box that is a must if you want the steering to feel like a modern race car.
http://www.firmfeel.com/
If you are looking to ditch the factory K-member check out Reilly Motorsports. I hear great things about their setups and they offer tubular k-members and a 4 link rear setup.
http://www.reillymotorsports.com/store/home.php
For chassis stiffening kits check out US Car Tool. https://store.uscartool.com/
Another great vendor is Doctor Diff. Great quality products and service. He has brake kits that use a viper caliper with 14" or 13" rotors, axles, rear ends, and master cylinders. http://www.doctordiff.com/
XV has had some bad press lately. I have ordered a bunch of small parts from them and they have been great. But others have complained about crap quality and bad customer service regarding their full suspension setup. It does look good though.
There are plenty of other companies that offer parts for Mopars but the above are the only companies I have dealt with. Others that have great parts are: QA1, Magnumforce racing, PST Suspensions, Ridetech, Schwartz Performance, Baer brakes, and Wilwood brakes.
MidnightSpecial
05-14-2013, 03:22 PM
Thanks Jeff. Wish I had that kind of cash to buy your frame. Looks awesome!
I appreciate it 69 Charger 440. That helps me out a lot. All of them just got added to my "One sweet day" bookmark folder!
SparkyRnD
05-15-2013, 05:47 AM
we are getting into Mopar radiators, starting with Wracker's duster. WE will be adding more models to the line up as the year goes on.
GMachineDartGT
05-21-2013, 05:01 AM
Bergman Auto Craft is a pro-touring oriented facility. Since we have track experience and we're a shop, we can help with all the parts necessary to create a solid, balanced package. Bergmanautocraft.com
Modo Innovations
05-25-2013, 03:47 AM
We have pedal cover sets in stock for classic Mopars. See link below.
modoinnovations.com/mopar_pedals.html (http://www.modoinnovations.com/mopar_pedals.html)
MidnightSpecial
05-28-2013, 12:43 PM
Thanks for the input everyone!
Looking for some drop leaf springs. The biggest drop i could find was Hotchkis with a 1 inch drop.
High Plains Mopars
05-28-2013, 01:00 PM
Talk to Firm Feel. They offer 1" and zero arch oval track spring along with the required hangers to match up their alternate lengths. You also might call Espo Springs and Things. They can custom build leaf packs in plus or minus heights on request.
There also are Speeedway, Afco, and Landrum, but be aware that using their springs, which are based off the Mopar oval Track springs, require different hangers than stock.
in their stock set up, you should only have a couple of inches of arch, tops. Might need to look into drop hangers and replace the shackles with sliders.
DTM Racing
05-29-2013, 05:34 AM
And becareful, you are going to run out of tunnel clearance for your driveshaft and pinion really quick when you go lower than the Hotchkis Springs.
High Plains Mopars
05-29-2013, 05:48 AM
There also is Magnumforce Racing for coil over conversions and a variety of other stock based components.
http://www.magnumforceracing.com/
